How Do You Calculate Expected Values in Probability Games?
  • Context:
  • Thread starter Thread starter oyth94
6 replies · 5K views
oyth94
I am so lost on how to do these questions:.
1.Suppose you start with eight pennies and flip one fair coin. If the coin comes up
heads, you get to keep all your pennies; if the coin comes up tails, you have to give
half of them back. Let X be the total number of pennies you have at the end. Compute
E(X)
how do you find E(X)?
2. Suppose you roll one fair six-sided die and then flip as many coins as the number
showing on the die. (For example, if the die shows 4, then you flip four coins.) Let
Y be the number of heads obtained. Compute E(Y)
E(X)
Well, by definition, if $X$ is a random variable, then
\[E[X]=\sum_i x_i\mathbb{P}(X=x_i)\]
where $x_i$ is the value $X$ can take on, and $\mathbb{P}(X=x_i)$ is the associated probability. Let $x_1$ represent the number of pennies you have when you flip heads (i.e. $x_1=8$ since you keep all the pennies you have in this case) and $x_2$ represent the number of pennies you have when you flip tails (i.e. $x_2=4$ since you lose half of what you started with). Since you're flipping a fair coin, we have $\mathbb{P}(X=x_i)=\frac{1}{2}$, $i=1,2$. Assuming that you're only flipping the coin once, we have that
\[E[X]=\sum_{i=1}^2 x_i\mathbb{P}(X=x_i)=8 \cdot \frac{1}{2} + 4\cdot\frac{1}{2} = 4+2 = 6.\]
The second one is a bit more interesting. If $Y$ represents the number of heads obtained, we note that $y_i\leq 6$. Thus, we let $y_i=i$ for $i=1,...,6$. Then the probability of having $i$ heads ($i=1,\ldots,6$) is $\mathbb{P}(Y=y_i)=\dfrac{1}{2^i}$. Therefore,
\[E[Y]=\sum_{i=1}^6 y_i\mathbb{P}(Y=y_i)= \sum_{i=1}^6\frac{i}{2^i}=\ldots\]
I'll leave it to you to simplify the sum.
I hope this makes sense!
Yes thank you so much! i ended up getting the same answer for the 1st question. I am still working on the 2nd.
I came across another question though
Suppose you flip one fair coin and roll one fair six-sided die. Let X be the
product of the numbers of heads (i.e., 0 or 1) times the number showing on the die.
Compute E(X)
can you help me please??
Compute E(X)
Here, if $X$ represents the product of the number of heads with rolled die value, we let $x_i=i$, $i=1,\ldots,6$. In this case though, $\mathbb{P}(X=x_i)=\dfrac{1}{2}\cdot\dfrac{1}{6} =\dfrac{1}{12}$ because the chance of getting a heads is $\dfrac{1}{2}$ and the chance of rolling a 1 through 6 is $\dfrac{1}{6}$ since we're working with a fair die. Therefore,
\[E[X]=\sum_{i=1}^6 x_i\mathbb{P}(X=x_i) = \sum_{i=1}^6\frac{i}{12}=\ldots\]
E(X)...
There are two not well specified points...
a) if You remain with one penny the game is over or You can continue and lose half penny, a quarter of penny and so one?...
b) is the number of possible flippings finite or unlimited?...
Kind regards
$\chi$ $\sigma$
E(X)...
Supposing that the game is over when the player has only one penny, then the problem is Markov type with four states...
1- The player has 8 pennies...
2- The player has 4 pennies...
3- The player has 2 pennies...
4- The player has 1 penny...
The transition diagram is represented in the figure...
http://d2yq0g4vt6ipuo.cloudfront.net/30/b4/i72594480._szw380h285_.jpg
... and the transition matrix is...
$\displaystyle P = \left | \begin{matrix} \frac{1}{2} & \frac{1}{2} & 0 & 0 \\ 0 & \frac{1}{2} & \frac{1}{2} & 0 \\ 0 & 0 & \frac{1}{2} & \frac{1}{2} \\ 0 & 0 & 0 & 1 \end{matrix} \right| $ (1)
If n is the number of flipping and $p_{i}, i=1,2,3,4$ the elements of first line of $P^{n}$, then the expected value of X is...
$\displaystyle E \{X\} = \sum_{i=1}^{4} p_{i}\ 2^{4-i}\ (2)$
Let's proceed for some values of n...
$n=1, p_{1}= \frac{1}{2}, p_{2}= \frac{1}{2}, p_{3}=0,p_{4}=0 \implies E \{X\} = 6$
$n=2, p_{1}= \frac{1}{4}, p_{2}= \frac{1}{2}, p_{3}=\frac{1}{4},p_{4}=0 \implies E \{X\} = \frac{9}{2}$
$n=3, p_{1}= \frac{1}{8}, p_{2}= \frac{3}{8}, p_{3}=\frac{3}{8},p_{4}=\frac{1}{8} \implies E \{X\} = \frac{27}{8}$
$n=4, p_{1}= \frac{1}{16}, p_{2}= \frac{1}{4}, p_{3}=\frac{3}{8},p_{4}=\frac{5}{16} \implies E \{X\} = \frac{19}{8}$
$n=5, p_{1}= \frac{1}{32}, p_{2}= \frac{5}{32}, p_{3}=\frac{5}{16},p_{4}=\frac{1}{2} \implies E \{X\} = 2$
$n=6, p_{1}= \frac{1}{64}, p_{2}= \frac{3}{32}, p_{3}=\frac{15}{64},p_{4}=\frac{21}{32} \implies E \{X\} = \frac{13}{8}$
$n=7, p_{1}= \frac{1}{128}, p_{2}= \frac{7}{128}, p_{3}=\frac{21}{128},p_{4}=\frac{99}{128} \implies E \{X\} = \frac{177}{128}$
$n=8, p_{1}= \frac{1}{256}, p_{2}= \frac{1}{32}, p_{3}=\frac{7}{64},p_{4}=\frac{219}{256} \implies E \{X\} = \frac{315}{256}$
The fact that $E \{X\}$ tends to 1 for n 'large' of course is not a surprise...
Kind regards
$\chi$$\sigma$
i know that X = the product of the two but how come P(X=xi)? isn't that if you're only finding the probability for the dice?
so to find X can we follow the theorem for independence since the two events are independent from each other? E(XY)=E(X)E(Y)
