How Do You Calculate the Acceleration of a Satellite in Circular Orbit?
The discussion revolves around calculating the acceleration of a satellite in a circular orbit around Earth, given a gravitational field strength of 4.5 N/kg. Participants explore the implications of this value and its relation to the satellite's motion.
  • Mixed
  • Some participants attempt to derive acceleration using circular motion formulas, while others question the validity of using 4.5 N/kg as the acceleration. There are discussions about the necessity of knowing the satellite's mass and the implications of gravitational force on acceleration.
The conversation is ongoing with various interpretations of the problem. Some participants suggest that 4.5 N/kg represents the gravitational field strength rather than the satellite's acceleration, while others argue that it can be directly interpreted as the acceleration. There is no clear consensus, but multiple lines of reasoning are being explored.
Participants note the lack of information regarding the satellite's mass and the need for additional details to fully resolve the problem. The original question is part of a larger problem set, and the context of previous parts may influence interpretations.
hydrocarbon
A satellite is designed to orbit Earth at an altitude above it's surface that will place it in a gravitational field with a strength of 4.5N/kg
b)assuming the orbit is circular, calculate the acceleration of the satlellite and it's direction.
since the satellite is rotating around the Earth i used circular motion formula: a=v^2/r but since i wasn't provided any velocity i have to derive from the formula but i don't know where to start can i get some help please? thanks
hey carbon,
I am really exited to reply to this question. This is actually my first time on this site.
to start off, the answer is right in front of you. A Force is defined as a Mass times an Acceleration. If F=m*a then a=F/m correct?
voila!
you have the acceleration. a=Newtons/kilograms. 4.5N/kg is really the acceleration because it is a= 4.5N/1Kg. do you see that?
For the second part, to find the direction you do not need the formula a=v^2/r. Heck, you do not need this formula for the entire problem. All you need to realize is that the direction of the acceleration is ALWAYS towards the point where it is being accelerated towards. In this case, the point being accelerated towards is the center of earth. THE ACCELERATION in this problem is always DIRECTED towards the CENTER OF EARTH!.
if you have anymore question on this or any difficulty understanding what i wrote, just let me know. It has been a pleasure
-Alex
i don't think the answer is 4.5N/Kg. they woudn't give me the answer in the question and then ask me to calculate it, wouldn't make sense. and the mass of the satellite is not given, so F=ma is not applicable in this case.
I also thought the same at first but tried using different formulas but there were too many variables. I would also like to mention that a force is not expressed is N/kg. N/kg is an ACCELERATION. A force is expressed in N. To show you an example using F=m*a, N=kg*(N/kg) but not (N/kg)=kg*(N/kg) . So the 4.5 that you gave HAS to be the acceleration because it is expressed in N/kg.
to use the equation F=G*m1*m2/(r^2) to find the acceleration, you would need to know r.
to use a=v^2/r you would need to know either the time of orbit or the velocity and the radius
to use F=m*a you would need to know the mass of the satellite
Do you see my point, if you said that 4.5N was the force, none of these would work with the given info. You need more information to solve this problem.
Make sure that the source where you got the problem from mentions the mass of the satellite in previous pages.
[tex]g = \frac{GM}{r^2}[/tex]
Using the above equation, with g=4.5 N/kg, G=gravitational constant, M= Earth's mass you can calculate the altitude the satellite would have in order for it to experience that specific gravitational force. This is R.
Now, in order for the satellite to orbit the planet and not just fall down, you need to balance the forces:
[tex]F_{net}= \frac{M_{sat} v^2}{R}[/tex]
[tex]F_{grav}= \frac{M_{sat} M_{earth} G}{R^2}[/tex][tex]\frac{M_{sat} v^2}{R}=\frac{M_{sat} M_{earth} G}{R^2}[/tex]
[tex]v^2=\frac{M_{earth} G}{R}[/tex]
As you can see, the mass of the satellite cancels out so it is irrelevant.
Now you have the velocity and the radius so you can calculate the acceleration using your a=vv/r equation.
Newtons/kg are not primitive units (i.e., units expressed as the produce of powers of mass, length, time, electrical charge). What is 4.5 N/kg in primitive units?
The satellite's mass is not needed to solve this problem.
It really is as simple as that. (Just as tiale11 described in his first post.) Of course you'd express the acceleration in its normal units.
Just call the mass of the satellite M. You don't need the actual value.
I see that this is part "b" of the problem. What was part a?
I don't think it is that simple...if that were the acceleration of the satellite then that would imply it has no orbital velocity, and hence falls straight back down to earth.
Why in the world would you think that? The acceleration still equals [itex]v^2/r[/itex].
Notice that 4.5N/kg is the strength of the gravitational field, not the acceleration of the satellite.
But since the gravitational force is proportional to the mass, this is the acceleration. Note that near the Earth's surface, the gravitational field strength is called g, which equals 9.8 N/kg = 9.8 m/s^2.
Notice that 4.5N/kg is the strength of the gravitational field, not the acceleration of the satellite. My post above(#5) outlines how to balance the forces to find the acceleration of the satellite.
So what you're saying is that my post (#5) is incorrect? I find this hard to believe...
4.5 N/kg is the acceleration of the satellite. The only force acting on the satellite is gravity; there are no forces to balance.
It's all unnecessary. F=ma works just fine. F = M(4.5 N/kg) = Ma, thus a = 4.5 N/kg (or m/s^2). (Gravity is the only force acting on the satellite.)
http://www.glenbrook.k12.il.us/gbssci/phys/Class/circles/u6l4c.html
The other force is centripetal
I haven't checked yet if both methods give the same answer, that would be amusing :-)
There's only one force acting, but OK.
Fine. Now divide by M_sat:
[tex]a = \frac{v^2}{R}=\frac{M_{earth} G}{R^2}[/tex]
Realize that the right hand term is the gravitational field strength, as given.
You don't need to solve for the speed.
Hint: The Newton is not a primitive unit. Rather one Newton is defined as the force needed to make a mass of one kilogram accelerate at one meter per second squared. Applying Newton's second law, [itex]1\,\text{Newton} = 1\,\text{kg}\cdot\text{meter}/\text{second}^2[/itex]. What is [itex]1\,N/kg[/itex]?
There's only one method. "Centripetal force" is not another force in additional to gravity. Gravity is the centripetal force!
This makes it more clear.
touche
hey kreil,
you really did not answer the original question. its nice that you derived the formulas but how exactly do they help you? you still have 3 unknowns: the velocity, acceleration, and the radius. a N/kg is not a centripetal force but is the centripetal acceleration. The answer to the original question is a=4.5m/s^2 and the direction is towards the center of the Earth. No computations are needed all that is needed is to know how to read UNITS. Thats it!
no tiale11 a calculation is needed. the question ask to "calculate the acceleration of the satellite and it's direction" the question I'm asking is how to munipulate the centripetal formula
As has been said previously, a calculation is really not required to answer this question. You are given the magnitude of the acceleration, the only thing you need to determine is the direction, which again doesn't require a calculation.
then you would definitely get this question wrong if you were taking this course. because the question asks for a calculation. so the teacher is going to look for one. previous questions i thought were messed up and could not be answered the teacher actually did answer it and i lost marks, so trust me the answer is not 4.5m/s^2 that would be way to easy.
Just because it's easy does not mean that it's wrong. Rather than argue with folks who are trying to help, I suggest you reread through this thread and understand the arguments given.
I also suggest that you post the entire problem exactly as given, not just part "b". Maybe the context of the entire problem will make it clearer.
let me just ask you this hydrocarbon
what is a Newton/kilogram equal to?
a) a force
b) an acceleration
c) an acceleration
d) answers b) and c) and never answer a)
***hint there are 3 possible answers*****
I know how to read units, and i never questioned that the 4.5n/kg was an acceleration, I simply doubted the problem would be that trivial. As it stands, this question is simply ridiculous.
  • · Replies 41 ·
  • · Replies 24 ·
  • · Replies 27 ·
