How Do You Calculate the Required Amounts for Buffer Solutions?
  • Thread starter Taryn
    Buffer Ph
10 replies · 13K views · last reply
Taryn
Hey I have been having a lot of trouble in solving these problems and I have exams soon and I really don't know where to start, I know u aint meant to give the answers so instead would someone please go through all of the steps to finish this!
I really need some kinda help, This question was in a quiz and I was so confused as to wat I needa do... I am going to get help from a lecturer as well but inorder to study it I need some help please.
A buffer solution of pH = 5.30 can be prepared by dissolving acetic acid and sodium acetate in water. How many moles of sodium acetate must be added to 1.0 L of 0.25 M acetic acid to prepare the buffer?
The answer is meant to be 0.90mol but I have no Idea how to get to that!
Also one more We mix 100 mL of 0.20 M HBr and 50.0 mL of 0.40 M NaC1O. What is the pH of the resulting solution? Ka(HC1O) = 3.5 x 10-8
for this one i Wrote out the equation... and found that the concentration of HClO was 0.1333 or something like that... then I just had no idea where to go from there, I no that pH=pka- log(acid/base) but I just didnt no how to get to that point... I changed Ka(HClO) to pKa by using -log3.5 x 10- 8 but as I sed not sure where to go.
Could anyone please help
Do you know how to calculate the acidity consant for buffer solutions?
Taryn said:
do you mean Kw and Kb coz I think so
I mean Ka perhaps you use different notantion? Anyway, the relationship between Ka and [H+ is given by;
[tex]K_{a} = [H^{+}] \times \frac{[\text{salt}]}{[\text{acid}]}[/tex]
Where Ka is the acidity constant of the acid.
I will give it a go... but i wat has me a little stumped is what happens to the pH, I obviously have to use that somewhere don't I?
wait a second I understand now I think, I will work it all out and if I have a problem I will just post it on this agen, thanks a lot.
You'll need that to work out the hydrogen ion concentration, you'll also need to look up Ka for acetic acid.
okay sorry just one more question, I am a little confused... just coz wat will be the [H+], I wrote this, 1.8E-5=[H+] x [salt]/[o.25]
Then after I find the [salt] then I will just use n=c* volume right?
If you can't give me anymore help that's fine!
That looks good to me. You need to use you pH value to calculate the [H+], remember that;
[tex]pH = -log[H^{+}] \Leftrightarrow [H^{+}] = 10^{-pH}[/tex]
Yes, you would usually do that, but since the solution is dissolve in one litre, the calculation becomes n = c x 1 and therefore in this case; n = c
Do you follow?
thanks very much that was heaps helpful and now I understand wat to do, don't know y I didnt think of that at the time.
