How Do You Construct an Orthonormal System from Functions?
  • Thread starter Thread starter overseastar
    System
15 replies · 7K views
overseastar
Hey,
I've taken linear algebra a long ago, and now came across a simple-looking question that i need help with
Construct an orthonormal system from the three functions:
1, x, 3x^2 - 1
Can anyone give me a pointer to solving this question?
Thanks a bunch!:blushing:
oh ya, this question is from a calculus homework before we get into Fourier Series and integral, so I don't think it wants us to apply Gram-Schmidt method.
ortho, and normal, only make sense with respect to an inner product. You haven't given one. And just because you've not been taught the formal proof of Gram-Schmidt doesn't mean you're not supposed to figure it out on your own; it is merely projection formally written down and not at all a tricky thing to figure out on your own.
1 what?
I can think of many different inner products on function spaces, and polynomial rings, none of them is called 1.
Sorry...Here's the entire question
Show that 1, x, 3x^2 - 1 are orthogonal functions with respect to the weight function 1 on the interval [-1, 1]. Construct an orthonormal system from the three functions.
I got the first part of the question, I'm stuck on the orthnormal part.
Currently looking through linear algebra notes, not quite understanding how to do it using Gram-Schmidt.
You know how to do projection? Ie given vectors v and w write w as the sum of a vector parallel to v and one orthogonal to v. That's all gram schmidt is, but you just do it again, and again, and again...
I thought Gram-Schmidt is used to find orthogonal basis only.
Sorry I might sound dumb, but the last time I took linear algebra was 2 years ago...don't remember much from it.
You can't get from a set of orthogonal vectors to a set of orthogonal vectors all of length one?
If I were to say here are u and v two orthogonal vectors (none of which is zero), you can now write down two orthogonal vectors of length 1, right? I can't tell if you're kidding me because you think I"m being patronizing or if you can't find a vector of length one from another vector (it has been some years you say since you did this).
:bugeye: I'm not a very wordy person and I learn from seeing equations and numbers and examples, I guess it's kinda hard to explain it like that. Thanks for your help, I'll think about it for now.
according to my notes, it says that a system of orthogonal functions w.r.t. weight q of [a, b] is also orthonormal if (see attachment) for all m. Is that what you meant?
If v is a vector (not the zero vector) then v/|v| is a unit vector in the same direction.
So if i were to rewrite the 3 functions in terms of vectors, would they become like this?
0 0 1 <-- 1
0 1 0 <-- x
3 0 -1 <-- 3x^2-1
so 1st vector would be
Ok, I finally understand the part after the unit vector.
What is the next step once I've got the unit vector for each of the function?
