How do you integrate ∫(4/(2x-1))dx correctly?
  • Thread starter Thread starter Physicist3
    Integrating
Physicist3
The problem that we have been given is to integrate the following: ∫( [itex]\frac{4}{2x-1}[/itex] )dx
I understand that the when [itex]\frac{a}{ax+b}[/itex] is integrated, the result is ln(ax+b) + C.
I have been told I need to make the numerator the same as the integer infront of the x term of the denominator (2) so that the equation meets the format to be [itex]\frac{a}{ax+b}[/itex], where a = 2 and b = -1. My lecturer informed me that I should change the 4 of the numerator from 4 to 2 and then place a 2 infront of the integral so that it looks like the following:
2∫([itex]\frac{2}{2x-1}[/itex]).
What I can't understand is why the (2x-1) term doesn't now become (x-0.5) if the 2 at the front of the integral means that the statement will be multiplied by 2, as the top is essentially multiplied by 2 but not the bottom. I may have missed something completely obvious here but this is bugging me slightly.
Thanks
Thanks
The reason you factor out a 2 from the numerator is so that the substitution is obvious.
##u = 2x-1 \Rightarrow du = 2dx##
Another way to go is to bring the 4 in the numerator out, and factor 2 out of the denominator.
$$ \int \frac{4 dx}{2x - 1} = \frac{4}{2} \int \frac{dx}{x - 1/2} = 2 \int \frac{dx}{x - 1/2}$$
The last integral is pretty easy to do.
Personally, I would not do it that way, anyway. Starting from [itex]\int 4dx/(2x- 1)[/itex] I would say "let u= 2x- 1. Then du= 2dx". Now I can divide both sides by 2 to get "(1/2)du= dx" and the integral becomes [itex]\int (1/2)(4) du/u= (2)\int du/u[/itex] which gives the same thing.
