I hope so because I know how hard math can be if you start missing things here and there...it makes future math courses quite hard. Let me see if I can explain this one more time, yeah?
Sqrt. 25
Have you ever done what I believe is called a "factor tree"? You write 25 down on a piece of paper and then start breaking it down. In this number's case, you're only going to be able to write down two 5's. Just in case you need to refresh your memory (I don't know what it is that's confusing you so I figured I'd just go down the line.
http://nlvm.usu.edu/en/nav/frames_asid_202_g_3_t_1.html" is a good site you can use to practice.
The square root of 25 is 5 because 5 squared (Five times itself or 5
2) is, well, 25.
Sqrt. x6
Ignoring the Square Root part for now, that basically means:
x * x * x * x * x * x
When finding the square root of a number, you're looking for a number that, multiplied by itself, gives you the number inside the sign. Just in case I've confused you...
Sqrt. 100
What number times itself equals 100? In other words, what number squared (ex. 3
2 = 3 * 3 = 9 so 3 squared is 9) equals 100? Answer= 10. See a pattern? When squaring something, you're always looking for a number you can multiply by itself. 2 * 2, 3 * 3, 4 * 4, 5 * 5, etc. You're always multiplying
two numbers together.
Thus, you circle pairs of the same term. You have six x's...
You have three pairs of x's. That means you can simplify Sqrt. x
6 to simply x
3.
Let's try mixing the two types of problems now.
Sqrt. 25x
First, break it down.
Sqrt. 5 * 5 * x * x * x * x * x * x
Circle pairs of similar terms.
Simplify.
5x
If that doesn't help you, try looking at this site http://regentsprep.org/Regents/math/radicals/Lsimplify.htm".
