How Does a Complex Number Represent a Circle in an Argand Diagram?
13 replies · 4K views
Homework Helper
[SOLVED] Urgent help needed with complex numbers
a complex no. z is represented by the point T in an Argand diagram.
[tex]z=\frac{1}{3+it}[/tex]
where t is a variable
show that z+z*=6ZZ*
and that as t varies,T lies on a circle, and state its centre
Did the first part easily.
Need help with the 2nd part with the circle
so far I multiplied z by z*/z* to get
[tex]z=\frac{3-it}{p+t^2}[/tex]
Do I now say that let z=x+iy and then find |z| and the modulus of the otherside (with t) and put that in the form [itex]x^2+y^2+2fx+2gy+c=0[/itex] ?
p is 9, right? Sure, you now have x=3/(9+t^2) and y=(-t)/(9+t^2). Eliminate the t in favor of x and y and write the quadratic form.
whoops sorry,p=9.
so then
[tex]y^2=\frac{t^2}{9+t^2}[/tex]
and from the eq'n in x
[tex]t^2=\frac{3}{x}-9[/tex]
making
[tex]y^2=(\frac{3}{x}-9)(\frac{x^2}{9})[/tex]
[tex]x^2+y^2-\frac{1}{3}x=0[/tex]
correct?
Small error here: Wasn't y = -t/(9+t^2) ? You didnt square denominator.
I did,I just left it out when typing
x^2/9 is 1/(9+t^2)^2
y^2=t^2/(9+t^2)^2. But everything else is correct, so I'll take that as a typo. Ok, so what's the center and radius?
Yeah, Defennder is on your tail so you are rushing it right? Don't. You have a sign error in the center. Fix it quick! If y=0 then x=0 and x=1/3 are both on the curve.
[tex]x^2+y^2+2(-\frac{1}{6}x)+2(0)+0=0[/tex]
f=-1/6
g=0
c=0
is the eq'n wrong or did I actually not sq. the denominator?
What are you doing? Just complete the square. x^2-2(x/6)=(x-1/6)^2-(1/6)^2. x-1/6 not x+1/6.
ahhh...my brain is idle
when put in the form [itex]x^2+y^2+2fx+2gy+c=0[/itex] ,the centre is (-f,-g)
sorry about my mistake
so the centre is (1/6,0) and radius is 1/6
No need to apologize. But, that's the problem with trying to memorize too many formulas you don't need.
yeah,I know but when I learned the equation of a circle, that equation was the one I remembered more than the other one.
But anyhow,thanks!
Now that I can agree with.
