How does dark matter suppress baryonic oscillations?
  • Level: High School
  • Thread starter Thread starter wolram
    Dark matter Matter
6 replies · 3K views
wolram
Dearly Missed
How does dark matter suppress baryonic osculations?
Astronomy news on Phys.org
The dark matter density in the early universe has a significant effect on the peaks in the CMB power spectrum, which strongly affects structure formation in the early universe, e.g., SDSS [see; https://arxiv.org/abs/1509.06529, SDSS-III Baryon Oscillation Spectroscopic Survey Data Release 12: galaxy target selection and large scale structure catalogues. You need a pretty healthy dose of DM to reconcile the observed structure with that expected based solely on baryonic matter and radiation pressure in the early universe [DM is not affected by radiation pressure]. For discussion, see http://background.uchicago.edu/~whu/intermediate/driving2.html. It is difficult to appreciate the strength of the case for DM without familiarity with CMB and SDSS studies.
I don't think it suppresses them. It just doesn't participate in them (as dark matter doesn't experience pressure to any significant degree). In practical terms this means that dark matter contributes to all of the odd peaks in the CMB power spectrum, while only the normal matter contributes to the even peaks.
But it does, doesn't it? - it suppresses the even peaks as it acts gravitationally against the bouncing baryonic matter so that it doesn't expand as much as a result.
This animation from Max Tegmark's site:
http://space.mit.edu/home/tegmark/movies.html
shows the effect each cosmological parameter should have on peak distribution.
@wolram Sean Carroll briefly explains how this works in this video:
starting at around 15:40 (or, -9.45).
If, in the primordial plasma, electrons were 2000x less massive than ions, wouldn't a given photon flux have had much greater effect on the motion of electrons over ions ? Wouldn't that create a charge separation which would suppress even peaks, mimicking non-baryonic DM in so doing ?
The mass of the electron doesn't change. Rest mass being an invarient quantity. If you have a different invarient mass it's not a electron. So where did you get this value ?
Edit your wording is extremely ambiguous can you clarify the above ?
