How does gravity get away from a source so it can pull back to the source?
  • Context: Graduate
  • Thread starter Thread starter GordonDengyo
    Gravity Pull Source
The discussion explores the nature of gravity, particularly how it is generated by massive objects like the sun and how it interacts with other bodies in the universe. Participants examine various analogies used to explain gravity, such as the sand funnel and rubber sheet models, and question their effectiveness in conveying the concept of gravitational attraction.
  • One participant questions how gravity, generated by the sun, can extend outwards to influence other bodies, suggesting that existing analogies fail to adequately explain this process.
  • Another participant introduces the concept of spacetime, arguing that the geometrical relationship between objects is what defines gravity in modern physics.
  • Some participants challenge the effectiveness of the sand analogy and the rubber sheet analogy, stating that they misrepresent the nature of gravity and spacetime.
  • There is a contention over whether gravity is a one-way force, with some asserting it is not, and others emphasizing the limitations of the analogies used to explain gravitational attraction.
  • A later reply suggests that gravity is not a force that travels but rather a result of the curvature of spacetime, as described by general relativity.
  • One participant proposes a helical screw analogy to visualize how gravitational attraction might work, despite the complexities involved.
Participants express differing views on the effectiveness of various analogies for explaining gravity, with no consensus reached on which analogy best represents the concept. The discussion remains unresolved regarding the fundamental nature of gravity and its representation in models.
Participants highlight limitations in the analogies used, such as the lack of time dimension in the rubber sheet model and the confusion surrounding the nature of gravity as a force versus a geometric property of spacetime.
GordonDengyo
If gravity is generated inside the sun by the mass of the sun, how does it initially get away from the sun out to the edges of our solar system(or the edge of the universe) so that it can pull everything back to the sun? I've heard the analogy about how it's like a funnel filled with sand and the sand is all flowing towards the hole in the bottom of the funnel but the problem I find with that is that the sand(representing gravity in this analogy) has already been put into the funnel. In reality, the sand(gravity) is generated inside the hole in the funnel(by the source) and would have to first get away from the hole so that it could flow back towards the hole. The analogy makes no sense without having some means of getting the sand into the funnel in the first place. A fountain in the center of the funnel could send the sand out so it could flow back to the center of the funnel but gravity is a one way force(always pulling back to the source) so that's not really an option. I have the same problem with the analogy of a stretched out rubber sheet with a bowling ball placed on it. Sure, it would make a depression in the sheet but in this particular analogy the sheet represents gravity and once again we have the problem of how the sheet exists where it is to begin with given that it's created inside the bowling ball. Maybe I don't have a good enough imagination to be able to understand physics.
I have never heard that odd sand analogy.
Anyway, if there are two distinct objects then there must be some geometrical relationship between them (otherwise they would not be distinct objects). That geometrical relationship is called spacetime. If there is a lot of stress-energy then that geometrical relationship will be detectably different from a flat Minkowski geometry. This curved geometry is what is called gravity in modern physics (GR).
Lay off the weed man.
The sand analogy is incomprehensible as given by you (probably your misrepresentation as you also mess up the following analogy).
GordonDengyo said:
...but gravity is a one way force(always pulling back to the source) so that's not really an option.
Incorrect. Gravity is not a one way street, even in the Newtonian view.
No, the sheet represents spacetime and serves to "explain" gravity according to GR.
No, the sheet represents curved space only (2 space dimensions), which is why it cannot explain how mass attraction works according to GR. You need the time dimension for this:
https://www.physicsforums.com/showpost.php?p=2046692&postcount=4
A curved sheet with a depression can also be used to visualize potential in Newtonian gravity. But this must not be confused with GR:
http://en.wikipedia.org/wiki/Gravity_well#Gravity_wells_and_general_relativity
I guess the conventional sheet analogy (gravitational well) only serves to represent 2D, but the analogies I have seen propose it in 3D and seemed to serve as a basic explanation for gravity in GR. I will concede only conceptual knowledge of GR, so can't comment more than that.
I can see how the gravitational well like the one linked is a poor analogy.
In both cases the pictures are 3D, but they contain a curved 2D manifold which is embedded in flat 3D space. The crucial point is, which of the 4 spacetime dimensions are represented by the curved 2D manifold. To explain mass attraction, you need to include the time dimension, so you have only one space dimension:
http://www.relativitet.se/spacetime1.html
The problem of the rubber sheet is, that it represents two space dimensions, and no time dimension.
No, no, you're fine. It's everyone else who has the problem. Just think about screwing a helical screw into a piece of wood. The helix turns and comes backwards towards you and then pushes against the wood. It is the reaction force of this which then pushes the screw forward. Think about it for a bit. It does make sense. This is a way of visualising how a gravity particle can cause a force of attraction despite it moving away from the object.
Gravity is not something that travels from the sun to our planet, somehow takes hold of our planet and then travels back to the sun...
Gravity is just a force between two masses. This force exists due to curvature of space-time as explained by general relativity.
You don't quite have the correct mental picture of the screw analogy above. The particle can exert a force of attraction due it's helical spin, although the particle itself continues on it's original direction of travel.
The standard model will be tested once and for all in the forthcoming LHC experiment.
Is there anybody else who believes that a simple particle picture of reality is entirely feasible? (i.e. that in the near future, General Relativity and the fabric of space-time will be proved to be the wrong picture)
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 27 ·
