How Does Momentum Conservation Determine Spring Compression in a Collision?
4 replies · 2K views · last reply
ntox101
A 1.0-kg block at rest on a horizontal frictionless surface is connected to an unstretched spring ( k =200 N/m ) whose other end is fixed. A 2.0-kg block whose speed is 4.0 m/s collides with the 1.0-kg block. If the two blocks stick together after the one-dimensional collision, what maximum compression of the spring occurs when the blocks momentarily stop?
law of conservation of momentum.
So far I started off by finding velocity after the collision.
Okay, the latex references are god-awful. I used algebra to modify the law of conservation of momentum and plugged in the values required and the velocity when the 2 blocks collide, I got 2.66 m/s . I then used that to calculate the kinetic energy of the masses when collided, and got 10.6J.
I just want confirmation that I am on the right track and any other helpers would be greatly appreciated.
Yup, you're definitely on the right track. Also, all your calculations are right so far.
Now just figure out the stretch of the spring using its potential energy.
Okay, maybe a stupid question. How do I find that out? I know that [tex]U_{s}[/tex] = [tex]\frac{1}{2}[/tex] k [tex]x^2{}[/tex]. Isn't the variable x the horizontal distance stretched? If so, that variable isn't given.
You should know the energy of the combined mass and its conserved. If I'm reading it right you aren't given x since you are trying to find the maximum compression of the spring which is x.
ntox101 said:
bump
Now that you found your final velocity, all of your variables are known and you can just apply the equations for conservation of energy.
