How does one find sample size without a given variance?
5 replies · 2K views
Eclair_de_XII
"The mean pH value of a certain chemical is to be controlled at ##\mu = 5##. Deviation from this target value in either direction is to be detected with high probability. For this purpose it is proposed to measure a ceratin number of samples from each batch and decide that the mean pH is different from 5 if the sample mean differs significantly from 5 at the 10% level of significance."
(b) "What sample size is needed if the probability of not detecting a change of one standard deviation is to be no more than 1%?"
##H_0: \mu = 5##
##H_1: \mu ≠ 5##
Basically, I'm interpreting this probability as the probability of a type-II error. So ##\beta = 0.01##. I know that the formula for the required sample size in this case would be: ##n=(\frac{\sigma}{E})^2##, but I don't know what ##\sigma## is. For that matter, I don't know what ##E## is supposed to be, either. So I'm kind of stuck, here.
What is the relationship between the variance of a sample and the variance of the mean?
The question , as quoted, has a part (b). Is there a part (a)?
Let's see... The variance of a sample is: ##s^2=\frac{1}{n-1}∑(\bar X - X_i)^2## and the variance of the mean, was ##Var(\bar X)=\frac{Var(X)}{\sqrt{n}}##? I'll get back to you on the matter of their relationship.
(a) "State the null hypothesis and the alternate hypothesis. What can you infer about the statistic ##\mu##?"
I didn't think it was related to the problem, so I decided to exclude it.
Instead of thinking about a statistic ("z") with a normal distribution, think about using the statistic with a t-distribution.
So what I'm gathering is to find an ##n## such that ##T=\frac{\mu - \bar x}{s/\sqrt{n}}=t_{n-1,\alpha /2}##.
In any case, though, my instructor told me to use ##-z_{\alpha /2}+\frac{\delta \sqrt{n}}{\sigma}=z_{\beta}##, and by setting ##\delta=\sigma##, I get ##n=(z_{\alpha /2}+z_{\beta})^2##.
