How Does Reducing Balance Wheel Dimensions Affect Angular SHM Frequency?
3 replies · 10K views · last reply
morbidpotato
Your boss at the Cut-Rate Cuckoo Clock Company asks you what would happen to the frequency of the angular SHM of the balance wheel if it had the same density and the same coil spring (thus the same torsion constant), but all the balance wheel dimensions were made one-third as great to save material. By what factor would the frequency change?
frequency = 1/2(pi) * square root of (torsion constant/I)
I tried finding the factor by setting up a second equation where frequency = 1/2(pi) * square root of (torsion constant/ m(r/3)^2 since I=mr^2 and got square root 3 but it didn't work. Is it because I'm using the wrong moment of inertia equation or is it something else? Please help and many thanks in advance.
I thought for a thin disk the I=1/2Mr^2, if you reduce the radius by a factor of three, the I shoud will be 1/9th the original, hence...
You also have to take into account the mass that change. Since the balance wheel dimensions were made 1/3 the original, you should have 1/27 the original mass.
