How Does Rotating Forces Through Equal Angles Affect Their Resultant?
9 replies · 2K views · last reply
batballbat
Two given forces act at two given points of a body; if they are turned round those points in the same direction through any two equal angles, show that their resultant will always pass through a fixed point.
i tried but could not make any progress with the problem
hi batballbat! :wink:
the first thing to do is to find where that point is …
so try the two simplest cases, one in which the first force points along AB, and one in which the second force points along AB …
what do you get? :smile:​
batballbat said:
if two forces act on different points of a body then at which point does the resultant act?
hint: add the two forces, then subtract the resultant …
that must be zero, and in particular, its moment about any point must be zero :wink:
if you have a force F along the line AP, and another force F along the line BQ,
and if the resultant of F and G is H,
the the resultant of F G and -H must be zero,
so in particular the moment of F + G - H about any point must be zero …
so what point must H go through?​
i have the problem of adding two vectors not acting at the same point. can u give me a general solution?
the point of application of the force does not matter,
only the line of application of the force matters …
if a force is acting at a point A, it's the same as if it was acting at any other point on the line through A in the direction of the force
batballbat said:
ok so the resultant acts along AD
what's D ?? there isn't a D ! :confused:
go back to my previous question …
is it one of the two given points on the body?
just give me an answer if u are not allowed to give a solution
