How Does Snow Accumulation Affect the Speed of Mining Carts?
  • Thread starter Thread starter chrizzd21
    Carts Momentum
The problem involves two identical mining carts traveling down a slope while accumulating snow, affecting their mass and potentially their velocities. The original poster seeks to understand how one cart, which shovels off snow, can arrive later than the other cart that allows snow to accumulate, despite both starting with equal momentum.
  • Participants discuss the implications of potential energy (PE) and kinetic energy (KE) conversions, questioning how the accumulation of snow affects the dynamics of the carts. There are attempts to apply conservation laws and explore the effects of mass changes on momentum.
The discussion is ongoing, with participants offering various insights and questioning the application of energy and momentum conservation in this context. Some suggest that the heavier cart may experience different effects due to the snow, while others explore the implications of shoveling snow versus allowing it to accumulate.
Participants note that the problem involves assumptions about the effects of gravity and mass on the carts' motion, as well as the role of external forces. There is a recognition that the situation may not conform neatly to standard conservation equations due to the unique conditions presented.
chrizzd21
Hello all,
I was given a problem which states that there are two identical mining carts, A and B, traveling down a distance L with equal velocities on two identical tracks. There is an identical man in each cart. As the carts travel, it begins to snow, which in turn increases the mass of both carts and leaves snow on the tracks. The man in cart A begins to shovel the snow off the cart, while the man in cart B let's the snow accumulate. Ignoring friction, cart B arrives at its destination before cart A. Using Kinematics, Energy-work theorems, and momentum equations, explain how this could be possible.
p = mv where p = momentum
pbefore = pafter
I had tried accounting for an increase in mass for the second cart, cart B, as the snow simply accumulates and isn't brushed off to the side like in cart A. The initial momentum of each cart is equal, but I am not sure how the final momentum of the carts changes.
Welcome to PF!
Cart B has more PE to convert into KE on the way down.
Delphi51 said:
Welcome to PF!
Thank you! I had thought about using Energy methods but was unsure how to express it; how would i go about explaining that in an expression? My thoughts were:
PEf + KEf = PEi + KEi
0 + 1/2(Mcart+Msnow)*Vf^2 = (MCart + Msnow)*(Gravity)*(L) + 0
Edit: After looking at it, doesn't the change in mass cancel out the change in potential energy? I've just run some test numbers and no matter how i change it i get the same velocities for cart A and B.
Okay, after talking with my professor quickly he hinted that to actually solve the problem, i need to use conservation of momentum equations and that since the motion is along the x-axis (which i forgot to include in my explanation >_<), the potential energy equation isn't necessarily true :(.
I had started by using the momentum before=momentum after equation, but the velocities for each cart end up remaining the same. The only thing i had thought might work was if i didn't include the added mass of the snow in the final momentum of the cart, which would give Cart B a larger velocity, but i don't think i can just drop the mass of the snow from that side of the equation completely.
Sorry, I gave you a bad idea.
I don't see why energy conservation doesn't apply.
Momentum conservation does not apply because the cars go down; gravity is an external force that increases momentum on the way down.
On the face of it, this is an old Galileo problem. The bigger mass falls at the same rate as the smaller one; if you imagine the masses broken up into equal sized little chunks, they all fall at the same rate and hooking them together doesn't change anything.
Could it be something to do with the fact that snow mass is gradually added?
No, because it is gradually added to both cars equally. Only the shoveling out is different. Shoveling out should not change the speed unless it is thrown forward or backward.
Maybe just that the heavier car with more energy and momentum suffers a smaller % loss in pushing aside the snow on the track?
I believe it doesn't apply because there is no change in the y direction, as the carts are going along parallel, level tracks. Basically in the x-y coordinate plane, the two tracks would just be moving to the right, or along the positive x-axis. I told my professor that the heavier cart would have to convert more PE into KE over the same distance, which he agreed with, but he said that wouldn't explain the problem in full detail.
implies going down.
So does "convert PE into KE".
The only answer I see is the bit about pushing snow aside, which would absorb the same amount of momentum from both carts, but would slow the lighter one more.
  • · Replies 24 ·
  • · Replies 24 ·
  • · Replies 20 ·
