Do the twin paradox predictions fail when spaceships return to the start point?
200 replies · 19K views
Ebeb said:
because there is no preference for a simultaneous collection, all 3D are physical. Which makes 4D physical too.
As a logical argument for the "block universe" (all 4D spacetime is real) viewpoint, this is flawed. See the Insights article I wrote about this:
https://www.physicsforums.com/insights/block-universe-refuting-common-argument/
PeterDonis said:
Good. Then what have we spent the last hundred or so posts discussing?
I have only been discussing this with you for a few posts, after you jumped in on a conversation I was having with Dale.
PeterDonis said:
I understand no such thing. I already explained what I understand in post #143.
Let me rephrase more in line with Dale's statement. As I have already outlined to you in post #146
Dale wrote:
Dale said:
One key physical constraint is that spacelike separated events cannot be causally related,
I replied:
name123 said:
Well presumably this is up for debate given "spooky" action at a distance.
And you replied:
PeterDonis said:
No, it isn't.
In post #146 you indicated that:
PeterDonis said:
The strict answer to it if we take the viewpoint of relativistic causality is that the question has no meaning, because relativistic causality does not tell you which events can be "causally related". It just tells you that spacelike separated events have to commute--i.e., what happens at them does not depend on their ordering. The fact that the events commute does not prevent what happens at them from being correlated.
As the discussion outline hopefully makes clear it is not an issue of whether relativity prevents commuting events from correlating.
The issue is whether relativity is compatible with spacelike separated events being causally related. As I understand it relativity does not prohibit spacelike separated events from being causally related because it does not prohibit particles of a negative mass from traveling faster than the speed of light.
Is it that in post #143 were you claiming that causality has no meaning in relativity? If you were, might I ask whether that became accepted after the "spooky" action at a distance experiments were performed? Either way, I don't think Dale was claiming that there is no such thing as causality, else he wouldn't have specified the constraint involved spacelike separated events.
Edit: If you were to claim that with relativity there is not such thing as causality, because of spooky action at a distance, I do not understand why causality cannot be relative. Also Everett's model is compatible with relativity is it not, and it has non-relative causality does it not?
To clarify, by "we", I meant all of the participants in this thread, not just you and me.
No, it isn't, because "causally related" isn't a well-defined concept. That's the point I'm making, which you continue to miss.
The well-defined concepts are: whether a given pair of events are spacelike, timelike, or null separated; and what the observed correlations are between measurement results at a given pair of events.
If you could define whether a pair of events are "causally related" in terms of those well-defined concepts, then it would also be a well-defined concept. But you can't. That's the point.
No. Go read what I wrote again.
I wasn't. Go read what I wrote again.
More precisely, you can't and still do justice to both the intuition that spacelike separated events can't causally affect each other, and the intuition that correlations that violate the Bell inequalities imply some kind of causal effect. The way to fix that is to give up the idea that "causally related" is a well-defined concept, and focus on the other well-defined concepts I gave. (Plus the well-defined concept of whether measurements at a given pair of events commute.)
In view of the confusion it is causing, I would recommend abandoning this language ("causally related"), as I explained in my previous few posts.
Everett's theory has the intuition that spacelike separated events can't causally affect each other and the intuition that correlations that violate the Bell inequalities imply some kind of causal effect does it not.
There is a difference between stating that you would choose to give up causality, and stating that your decision is not debatable and is compulsory for everyone that wishes to cling to a relativity interpretation. Apart from Everett's theory, relativity also seems to be open to the interpretation that spacelike separated events can causally affect each other, and that causality is relative.
Ebeb said:
No 3D world is physical?
The point is - how would you describe a 2d slice through 3d space? It exists. I can pick an infinite number of different ones that pass through a given point. But so what? It's not particularly interesting in any physical sense. It's just some random choice of slice. It may be tactically useful to consider such a slice (the ecliptic plane is one such) but there's nothing in the laws of physics that picks it out.
That's why we call a 3d slice through 4d spacetime unphysical. Which one you pick depends solely on your choice of simultaneity criterion. There's no physical law that picks it out.
name123 said:
So what if you can't "send knowledge of that outcome and have it arrive at the location of the second event before that second event occurs"? The issue was whether the two events can be interpreted as being causally related.
If news of the outcome of the first event can't possibly, even in principle, reach the second event before it occurs then the first event can't possibly be the cause of the second event.
name123 said:
Everett's theory
Everett gave an interpretation, not a theory; his interpretation of QM makes the same predictions as all other interpretations of QM.
I don't think these conflicting intuitions are tied to any particular interpretation of QM. In fact I don't think they're tied to QM at all; they are leftovers from pre-quantum thinking that simply have to be discarded.
I have never said I would choose to give up causality. You need to read more carefully.
No, because "causally affect" is not well-defined.
I don't know where you're getting that from. All of the concepts that I said were well-defined in previous posts are invariants in relativity.
The idea would be that the measurement of the first event instantaneously influenced the outcome of the second event. Not that there was a delay. A word like "news" is confusing, as it tends to imply sending information from one conscious observer to another. The two things are quite different. There could be instantaneous causality (such as that in Bohemian Mechanics for example), and yet no way for observers to exploit it in order to send information to one another.
If there was no way to exploit it to send information to one another it does not imply that there is no instantaneous causality.
name123 said:
Well I think those experimental results have been interpreted as being the measurement of one particle causally influencing the measurement of another particle even though the events were spacelike separated, and so have been interpreted as contradicting the statement "spacelike separated events cannot be causally related".
"Have been interpreted..." by whom? I am aware of no serious peer-reviewed claim of that sort - if you think you've found one, chances are that the word "causal" is being used in a different way than you're understanding it.
Again, do you have a source for this claim? It's a popular misconception, but in fact the objection to causal relationships between spacelike-separated events is not based on the impossibility of faster-than-light travel. The argument goes the other way: landing my FTL spaceship at the destination is caused by, among other things, the spaceship having taken off in the first place so FTL travel requires a causal relationship between two spacelike-separated events, and this is not allowed by relativity.
The objection to causal relationships between spacelike-separated events is based on Tolman's paradox and similar time travel paradoxes. Attempts to work around these problems are highly speculative and by no means generally accepted.
Ok, but his interpretation has the intuition that spacelike separated events can't causally affect each other and the intuition that correlations that violate the Bell inequalities imply some kind of causal effect does it not?
You wrote that
I assumed you meant that we should give up the idea that there is a causal relation between events. The idea of there being a causal relation between events was what I thought was implied by the idea of causality.
The concept of dimensions is used in relativity, and I thought a conceptual distinction was made between the three spatial dimensions and the time dimension, but an event's location in the distinct time dimension is not invariant for an event's location, only the spacetime interval is. The reason I suspect the theory is know as relativity is because it utilises concepts that are not invariant, but are relative.
Do you agree and think that are distinctions made between the 4 dimensions of spacetime or is their selection just arbitrary, like the dimensions of Cartesian space?
Maybe, but could you explain what you thought Einstein was thinking when he used the term "spooky action at a distance" for such a result?
I just thought that relativity only ruled out faster than light travel for things with a positive mass. And that these particles never traveled less than the faster than the speed of light. And the issue isn't whether the things are accepted, it is whether they are debatable.
Go back and read my post again. I already answered this question.
Then you thought wrong. In quantum field theory, i.e., QM combined with special relativity, "causality" means that spacelike separated measurements must commute--their results can't depend on the order in which they happen. That's all it means.
No, a distinction is made between timelike, null, and spacelike separation between events. But that does not require you to label one specific "dimension" as the "time" dimension. The fact that this is usually done in treatments of SR is a convenience, not a necessity.
I did. But let me rephrase. Is Everett's interpretation compatible with the intuition that spacelike separated events can't causally affect each other and the intuition that correlations that violate the Bell inequalities imply some kind of causal effect does it not?
Ok, so (taking a slightly logical positivist's approach, which apparently Einstein later backed off of) in quantum field theory "causality" means that spacelike separated measurements must commute--their results can't depend on the order in which they happen. That's all it means. So on what basis are you claiming that there can be no causality between spacelike separated measurements?
Edit: So you are not claiming that there is no causality. Just that there is no relation between one event and another other than a correlation. But presumably the claim that there is no relation is debatable.
I wasn't asking about distinction between spacetime intervals. The question was:
The point being could I chose the x and y spacetime coordinates and arbitrarily decide that they are the x and t coordinates and use them in the equations?
You're still not getting it. These two intuitions, in themselves, are not compatible. So nothing else can be compatible with both of them. You have to give up at least one. Or, as I have suggested, you can give up the idea of "causal effect" between a specific pair of events as a single thing, and focus on the other things I have already mentioned several times that are well-defined instead.
I have not claimed that. You really, really need to go back and read what I've actually said more carefully.
You can choose any coordinates you want. It doesn't change any invariants, including whether a given pair of events are spacelike, timelike, or null separated.
Also, the fact that you call a coordinate "t" doesn't mean it's a "time" coordinate. You have to look at invariants, such as whether events with the same ##t## coordinate are spacelike separated or not, to determine whether a "t" coordinate in a particular coordinate chart qualifies as a "time" coordinate. (Note also that it is perfectly possible to have a coordinate chart that has no "time" coordinate.)
So with Everett's interpretation if I understand it, if not count it as a consideration of my own.
There is no faster than light influence. So one measurement does not influence the other directly. If it were a binary issue, there could event A outcomes of
1) 0
2) 1
and
event B outcomes of
3) 0
4) 1
And that 2 distinct universes would be created and in one (1) matches with (4) and in another (2) matches with (3).
So that that the A outcome didn't affect the B outcome, but that the resultant correlations were influenced by the result (of either A or B) because it influenced how they were matched. .
I realize that, tried to fix it in an edit, but did it presumably too late.
So are you saying that if I there was a passer by traveling in the x direction that I could substitute their y coordinate (in which there is not change) for their t coordinate (for which there is a change) that it works out pretty much the same?
Edit: Such that you could describe the experience without knowing which way it was.
I said you can use any coordinates you want, but you still need to have a valid transformation from one chart to another. I'm not sure whether what you are describing is a valid transformation or not, because you haven't shown any math describing the transformation.
Ebeb said:
Maybe we disagree on the meaning of physical.
Yes, I think we do disagree on the meaning of physical. In that previous conversation I was very clear about what I mean by it. I have no desire to rehash it here.
So imagine a change in x and t, but none in y and z, and provide a transformation for changing it to a change in x and y, but none in t or z, such that it makes no difference to what the experience would be expected to be.
Well, I am not sure how to say it otherwise. Maybe: Any observable (including an “experience”) is a function only of events within its past light cone.
This still doesn't give an actual mathematical description of the coordinate transformation. But if it's a valid coordinate transformation, then it won't change any invariants, which means it won't change any physical consequences of the theory, including what anyone will experience.
This will work for classical SR, yes. If we include quantum mechanics, so that we are in the domain of quantum field theory, I think it would have to be rephrased as a statement about commutation relations, for example: any observable (including an "experience") can only fail to commute with events within its past light cone.
@name123 so there has been a whole bunch I missed today. Yes, I agree that it is “debatable” in the same sense that whether the Earth is round or flat is debatable. I.e. you will get people who argue any point. As @Nugatory mentioned, to the best of my knowledge this is not considered an open issue in the modern professional scientific literature.
Additionally, the brain is a classical object, governed by classical laws. See my recent post to @PeterDonis and his response. Although you have to use slightly weird language (regarding commutators) for quantum systems, you can be more straightforward for classical systems like the brain.
Bottom line: your experience at any moment is a function only of events in your past light cone at that moment, not of simuktaneous events. As such it is a relativistic invariant. Indeed, this is necessary because experience is an observable and all observable are invariants.
I beg to differ. The observation of correlation for entanglement is only based on setting of devices in its past light cone. Each local measurement's probability distribution needs only past light cone information. The weird part is that the observation of correlations depends on device setting events that were spacelike separated, and the correlation can't be explained by any model in which the local measurements are independent of each other.
However one is not forced to accept any generalization of strict SR causality. One unpalatable option (but enough to prove there is absence of necessity) is that the device settings are determined as of generation of the entangled particles.
Ebeb said:
If we consider an event 'car hits tree' then there is definitely car and a tree at a spacelike distance.
This jumped out at me. The event (which is just four coordinate values) says nothing whatsoever about the car or the tree except that they coincided (0 spacelike distance there) at some point in spacetime. Don't know if this helps, but I thought I'd try.
It might be interisting for the forum readers. As far as I can remember you call 'physical' only what is measured.
But this means one is not allowed to talk about a 3D universe of simultaneous events occurring now.
Which means we are not allowed to make a 3D cut though the apex of the lightcone.
Which also means we are actually not free to make 3D sections anywhere in 4D spacetime.
Then in post #126 you state <<no 3D world is physical. >>
If no 3D world is physical, then even a 3D world of the past, squeezed between the extent of the observer's past lightcone, is not physical.
Hence you contradict your "physical is only what is measured".
And you think it is all clear what you communicate? You might indeed think it, but that doesn't mean the reader agrees its all clear...
All I can say about this article is that it doesn't give any insight al all. Nobody fully understands what you write there. As far as I can remember -correct me if I'm wrong- there was a forum thread where the article was also discussed, you participated, but you didn't like what was being said there you all of a sudden closed the topic. That suffices.
The event is not coordinates. The event is: car hits tree. Hence it contains car and tree.
OK, so you need to understand that the event is no more than a label: (t, x, y, z). There is no car, tree, or distance involved (spacelike or otherwise).
