How Does Submerging a Sphere Affect Scale Readings?
  • Thread starter Thread starter jaded18
    Sphere Submerged
38 replies · 37K views
jaded18
http://session.masteringphysics.com/problemAsset/1011221/19/SFL_ap_6a.jpg
A cylindrical beaker of height 0.100 {m} and negligible weight is filled to the brim with a fluid of density rho = 890 {kg/m}^3. When the beaker is placed on a scale, its weight is measured to be 1.00 {N}. View Figure
A ball of density rho_b = 5000 {kg/m}^3 and volume V = 60.0 {cm}^3 is then submerged in the fluid, so that some of the fluid spills over the side of the beaker. The ball is held in place by a stiff rod of negligible volume and weight. Throughout the problem, assume the acceleration due to gravity is g = 9.81
------> What is the reading W_2 of the scale when the ball is held in this submerged position? Assume that none of the water that spills over stays on the scale.
________________________________________________________________
I know that the weight of the ball is 2.94 N, and that the beaker is 1 N... And that pressure= F/A and pressure = p_0 + density of liquid(gh) ... Help??
How does the water pressure change when the ball is submerged?
Another way to analyze this setup is to examine all the forces acting on the beaker and its contents. (Start by analyzing the forces on the ball. What must they add to?)
I don't understand ... Pressure force on the bottom is greater in order to balance gravity...
What is the pressure at the bottom of the beaker before the ball is submerged?
What is the pressure at the bottom after the ball is submerged?
Ok, so pressure at the bottom of the beaker before the ball is submerged ... well P=F/A and A of the beaker I don't know, but I know that the weight of the beaker+fluid = 1N. A=density(V) = 890(V) ... I'm stuck
after the ball is submerged, P=F/A and A of the ball is just (5000(60/(100^3)))=0.3m^2 ?? and force is just the weight which equals 2.94? so pressure is then 98 pa?? That sounds .. wrong
Another way of putting it... does the pressure change at the bottom of the beaker, from before and after?
The force on the bottom of the beaker is the pressure due to the water*area...
The normal force upward on the beaker = force due to pressure + weight of beaker...
this normal force is what the scale measures...
how do either of these 2 things change... "force due to pressure" or "weight of the beaker"
do they change at all?
Ah, ok, no, replacing the fluid volume with the object does not change the fluid ... so pressure force stays the same... By the way, how do you calculate the pressure?
exactly. everything's the same. it's a trick question. :wink:
you don't need it... you know the pressure force is the same... the weight of the beaker is the same... so the scale measures the same force... 1N.
I just looked it up and the answer key said 873 pa and i was wondering where the heck that came from. But what you're saying makes sense...
yeah, that's just rho*g*h = 890*9.81*0.1 = 873 pa
question: when is this p_0 101.3 kpa and when is it 0 ...
it depends on what exactly the question was asking for... did the question ask for the pressure at the bottom of the beaker, from inside...
was it asking for the difference in pressure between inside and outside?
Well when you were calculating the pressure at the bottom of the beaker before the ball was submerged and after the ball was submerged, you used p_0 = 0 in the equation p=p_0+rho(g)(h) for both cases
yeah... I should use p_0 = 101kpa both times. we also need to remember that there's a pressure outside the beaker acting upwards on the bottom of the beaker of 101kpa.
The 101kpa inside and outisde cancel... so that's why I didn't include it...
When you consider the force on the beaker...
Fnormal - (pressure inside)*area + (pressure outside)*area - (weight of beaker) = 0.
Fnormal - (101kpa + rho*g*h)*area + (101kpa)*area - weight of beaker = 0
see now that the 2 101kpa's cancel
Fnormal - rho*g*h*area - (weight of beaker) = 0
giving the same equation as before...
I am confused about this question. So what is the answer?
Do I use the formula, W= rho * V* g?
I know everything except for V... how can I find V when i only have the height?
Thank you
What do you think the answer is?
You don't need that to answer the question.
nevermind. that is wrong. i just tried it.
hmm looks like I'm really not understanding buoyancy! =(
If you can explain just how you are trying to solve the problem, perhaps we can point out where you are going wrong. Have you read the earlier posts in this thread? They contain hints as to how to solve this.
I'm trying to find the force of tension on the ball by the rod.
I know that...
Ft = Fb - mg
and Fb= density of fluid*V*g
V would be the volume of the ball (6x10^-5)m
I get an answer of 2.29.
But its not correct.
Somebody tell me where I'm going wrong?
Here is the information given from the question. Also the same as the first post.
A cylindrical beaker of height 0.100m and negligible weight is filled to the brim with a fluid of density rho = 890kg/m^3. When the beaker is placed on a scale, its weight is measured to be 1.00N.
A ball of density rho_b = 5000kg/m^3 and volume V = 60.0cm^3 is then submerged in the fluid, so that some of the fluid spills over the side of the beaker. The ball is held in place by a stiff rod of negligible volume and weight. Throughout the problem, assume the acceleration due to gravity is g = 9.81
I know that...
Ft = Fb - mg
That's fine. (Except that Ft = mg - Fb.)
Show exactly what you plugged in and maybe we can spot your error.
It seems as though the answer to "what is the weight of the ball" should be [m(ball)*g-rho_f*V*g]. Why is that not right?
Please state the exact question you are trying to answer.
In answering the original question:
It seems as though the answer should be:
W_2=m(ball)*g - rho_f*V*g
OK.
That would be the increase in scale reading if the ball were just dropped in and sunk to the bottom. But it's being held in place by a rod.
I misread the question, sorry. I understand that the scale will not change its reading, so W_2= 1N, but how would you find the weight of the ball? I thought it would be:
