matheinste
- Messages
- 1,068
- Reaction score
- 0
Al68 said:Each twin's age and clock readings reflect actual time elapsed. The reason for the difference is that the actual time elapsed is different.
Acceleration affects the spacetime paths, which affects the proper time elapsed. The only reason SR predicts different clock readings for the twins is because it assumes that each clock accurately records the elapsed time for each twin.
The above really says it all.
When talking of timelike intervals, which are the only type which can be traversed by a clock, the time recorded by an ideal clock while traversing this interval is said to be proper time whatever its motion or path through that interval. It is a measure of spacetime path length.
In a frame in which it is at rest the proper time recorded by the clock is the same as the coordinate time, that is the projection of the interval onto the time axis of that frame.
Since the coordinates in any inertial frame can be Lorentz transformed into coordinates in any other relatively moving inertial frame, the coordinates of a clock in any infinitessimal region of its travels can be transformed into those of a frame at which it as at rest in that infinitessimal region.
Since all inertial frames are equivalent in SR, each infinitessimal amount of coordinate time, which in each comoving rest frame is equal to proper time, can be summed, and, in the limit, as these infinitessimal regions are allowed to become smaller and smalle, so apprroaching zero, integrated over the path (timelike) of the clock to give the exact proper time, as a sum of coordinate times, for this path.
So there is nothing in this derivation of proper time which gives any clock any preference over any other clock as all proper times can be made equivalent to the sum of coordinate times of a clock in frames in which it is at rest.
In other words the time recorded by a clock can be viewed as the sum of coordinate times in inertial frames in which it is (for an infinitessimally small region) at rest, and since the use of all inertial frames is equally valid, all times so recorded are equally valid or "correct". So for a clock, any clock, the time it records, proper time, is for that clock THE time.
Matheinste.
