How Far is the Boat From its Original Position?
9 replies · 3K views
Benjamin_harsh
How far from its original position is the boat now?
With reference to ground, the water travels downstream for 2.5+3.5= 6 hours.
With reference to water, the boat went upstream for 1 hour. So the boat is
10/3×6−15/2×1=12.5 km downstream from the start.
A boat goes upstream for 3 hr 30 min and then goes downstream for 2 hr 30 min. If the speed of the current and the speed of the boat in still water are 10/3 kmph and 15/2 kmph respectively, how far from its original position is the boat now?
Final Equation: 10/3×6−15/2×1=12.5 km downstream from the start.
Why should we solve this question through references?
How boat went upstream for 1 hour if question clearly says boat goes upstream for 3 hr 30 min?
You seem to have stated the problem twice with different values. What is the actual statement of the problem, as stated wherever you got it from?
  • Skeptical
Because the boat is moving through the water, which is itself moving. If the boat's speed was only 10/3 km/hr, and it was traveling upstream, it would stay in the same place, relative to the ground, but would have traveled 10/3 km in an hour, relative to the water.
What references are you referring to?
Frames of Reference?
Moving on, in an effort to see how you attempted to solve this problem:
The information in your original post appears to be rather scrambled. I did manage to pick out the actual problem.
A boat goes upstream for 3 hr 30 min and then goes downstream for 2 hr 30 min. If the speed of the current and the speed of the boat in still water are 10/3 kmph and 15/2 kmph respectively, how far from its original position is the boat now?​
Then fast forward to what you call the
Final Equation: 10/3×6−15/2×1=12.5 km downstream from the start.​
I agree that this is the correct answer numerically, but does this solution make sense?
Let's see. 10/3 (km/h) is the speed of the water. That's downstream and with respect to (w.r.t) dry land.
Also, 15/2 (km/h) is the speed of the boat in still water. I.e. The boat travels at a speed of 15/2 (km/h) w.r.t. the water.
Digging through the OP, we find your explanation of where the 6 and the 1 come from and that both are in units of hours.
With reference to ground, the water travels downstream for 2.5+3.5= 6 hours.​
With reference to water, the boat went upstream for 1 hour.​
(By the way: I notice that your solution does use references.)
Multiplying 10/3 km/h by 6 h makes sense and could possibly be useful in solving this problem.
But, what do you mean by "the boat went upstream for 1 hour"? You then multiply this by the speed of the boat w.r.t. the water, which you subtract from the distance the water moved in the entire 6 hours.
The boat goes upstream for 3.5, not just 1 hour, then goes downstream for another 2.5 hours.
You have the boat going upstream for just 1 hour, then what? What does it do the other 5 hours?
You haven't fully explained your reasoning here.
How boat went upstream for 1 hour only if question clearly says boat goes upstream for 3 hr 30 min?
My doubt regarding the way of approach to answer.
"A boat goes upstream for 3 hr 30 min and then goes downstream for 2 hr 30 min". 3.5hr - 2.5hr = 1hr
So, that solution to the problem in the Original Post is not your solution? I misunderstood that.
Was that solution given to you written out in the manner you posted ? It does seem to me that the approach is somewhat unusual.
Can you show me another simple approach ?
Yes, we can get you started on another approach. But first ...
As to the question asked:
It is absolutely necessary due to the information given in the problem itself. The two given speeds are in reference to different objects: the land for the water, the water for the boat. Right?
Now for an alternate approach:
What is the boat's speed relative to land on the upstream portion of the trip?
What is the boat's speed relative to land on the downstream portion of the trip?
