How is 1/√(1-u'²/c²) = γ(1-vu_x/c²)/√(1-u²/c²)?
10 replies · 2K views
little neutrino
Hi. In the attached proof for Lorentz transformation for momentum http://www.colorado.edu/physics/phys2170/phys2170_sp07/downloads/lorentz_transformation_E_p.pdf, there is this step that I don't understand:
1/√1-u'2/c2 = γ(1-vux/c2)/√1-u2/c2
Can someone explain how they derived this? Thanks! :)
Which part of this step don't you understand? Can you show exactly where you get stuck?
I tried substituting the Lorentz transformation for u'
ux' = (ux-v)/(1-uxv/c2)
into the LHS
and simplifying it from there, but I couldn't derive the expression on the RHS :(
into the LHS
Yes, it's quite difficult algebra to derive this identity. You have three gamma factors and a velocity transformation formula to manage. You just have to keep working at it.
There is a quicker way using the properties of 4-vectors and the proper time of the particle if you are comfortable with those?
Actually, I've just noticed a very quick way simply using the transformation of the time coordinates ##t## and ##t'##.
Let me know if you are interested in the quick way!
into the LHS
Maybe this is a trivial point, but you have to use the Lorentz transformed expressions for ##u'_y## and ##u'_z## as well as ##u'_x##. Start with ##u'^2=u'^2_x+u'^2_y+u'^2_z## in the LHS. As PeroK says, there's a lot of messy algebra to work through, but it should work out.
Well, I'm certainly interested if OP isn't. :biggrin:
The relationship between the proper time of the particle and the two coordinate times is:
##\frac{dt}{d\tau} = \gamma, \frac{dt'}{d\tau} = \gamma '## (1)
Differentiate the transformation for time wrt proper time:
##t' = \gamma_V(t - Vx/c^2)##
##\frac{dt'}{d\tau} = \gamma_V(\gamma - V \gamma v_x/c^2) = \gamma_V\gamma (1- Vv_x/c^2) ##
Then, using (1) we have:
##\gamma ' = \gamma_V\gamma (1- Vv_x/c^2)##
In fact, you can derive the energy-momentum transformation much more easily by differentiating the components of position wrt proper time of the particle.
With rapidities (i.e. trigonometry), [itex]\theta'=\theta-\theta_V[/itex],
[itex]\begin{align*}\cosh\theta'<br /> &=\cosh(\theta-\theta_V)\\<br /> &=\cosh\theta\cosh\theta_V-\sinh\theta\sinh\theta_V\\<br /> &=\cosh\theta\cosh\theta_V(1-\tanh\theta\tanh\theta_V)\\<br /> \gamma_{u'}<br /> &=\gamma_{u}\gamma_{V}(1-uV)<br /> \end{align*}[/itex]
Sflr I was caught up with some stuff this week :/ I just figured out the algebraic manipulation after substitution of u' ; I realized that I had to observe the final expression more closely instead of blindly manipulating the algebra. Thanks so much for your help! :)
Yup, I finally worked through the algebra. Thanks! :)
Woah that's sweet XD Thanks for the alternative solution!
