How is Physics taught without Calculus?
117 replies · 21K views
vanhees71 said:
How do you define acceleration without calculus? You can make many words.
The acceleration is given by ##\frac{\Delta v}{\Delta t}##. For a constant acceleration, this is the acceleration; for a changing acceleration, this is the average acceleration; in a v-t diagram, this is the slope of the graph at a certain time.
No derivative needed. Yes, it takes some words, but then again, you need those same words to interpret the derivative.
I know, how these ideas of "calculus-free physics" look like: They do calculus all the time without systemizing it and make thus phyiscs even more difficult to understand than necessary!
A fraction is not a derivative. A derivative involves a limit. Yes, of course we use fractions in doing physics. We calculate stuff.
Reply
It's the derivative, whether you call it such or not! That's my point. You make your physics "calculus-free" by only hiding the fact that you of course use it. That's why everything becomes more difficult. The effectiveness of the adequate math is that you can derive general things in an abstract way and having it at hand for each concrete application. The "avoid math at any cost" makes physics more complicated instead of simpler!
Reply
We have reached the crux of this discussion and a likely place of agreement: teaching physics (above basic demonstrations) requires mathematics.
Due to exigencies of life, I learned, practiced and eventually taught several advanced concepts in physics from an electromagnetic field (emf) and QM perspective before formally learning university Calculus but definitely employed prodigious algebra, geometry, trigonometry and other transcendental functions with healthy use of set theory.
Seeing pages of frantic algebraic scribbling reduced to simple calculus equations, brought me nearly to tears while working with better educated peers. Calculus saves computation time and greatly deepens understanding of functions such as previously mentioned sine, cosine and tangent. One advantage of learning to operate a slide rule even after calculators became ubiquitous included deep exposure to logarithms and exponents; this exposure replaced by studying these functions via calculus.
Reply
(emphasis added)
Isn't it disquieting when prospective physics teachers are led to see abstractness as beneficial?
Reply
  • Skeptical
To the contrary! If physics teachers find out that abstractness is beneficial in making complicated things easier to express and explain, they may be better suited to provide this important experience to their pupils. Of course, you cannot start with the abstract things in high school, but you can start to teach the students the more and more abstract reasoning such that they gain an easier understanding through abstraction.
This is also well established by didactics research: E.g., for a long time mechanics has been introduced by considering 1D motions along a line first. Now a physics-didactics colleague of mine investigated this traditional approach compared to another approach, where one starts with motions in a plane and right from the start introduce vectors. That's of course on the first glance more complicated, but the result was better, i.e., the students didn't develop misconceptions easily induced by the older approach in not recognizing the important difference between vector and scalar quantities, which have to be corrected when turning to the more complicated 2D motions (e.g. circular motion) or even full 3D problems. That's of course not an example of calculus but rather algebra, but using the somewhat "more difficult/abstract" concept of vectors (introduced, of course, as directed straight connections between points or "displacements" identifying all such "arrows" as equal when you can parallel shifting them into each other, which is a pretty abstract concept!) leads to a better understanding of introductory mechanics than the older apparently simpler approach.
I don't say that you shouldn't start teaching physics early on without "higher math". Indeed it's clear that you should get pupils very early on excited about the STEM subjects, but it's good for a teacher to be aware that without the abstracter way you can in fact not really teach the full thing, and that you must be very careful to "elementarize" the material you like to teach them, not to induce miconceptions, which are hard to correct later on.
Reply
You might take a look at Barbeau's excellent book Polynomials, where he introduces the derivative as a function of functions - I suppose in physics speak we might call it a functional. No generalization to trig or other s[ecial functions, no fundamental theorem of calculus, no nothing. It's introduced simply as a polynomial one gets by following a partcular process on another polynomial.
Reply
With "using calculus" I assume you mean explicit usage of differentiation, integration etc. Newton's 2nd law is also a tensor equation under the Galilei group, but that doesn't mean I have to explain that to my students because "It's a tensor equation, whether you call it such or not." You don't use jet-theory in a first course in field theory, I suppose. Representation theory of the Poincare algebra in a first course on special relativity. And so on.
I disagree with your last point. I think you mean it becomes more complicated for you. Are you aware of any research that students experience it also that way?
Reply
Are we talking about HS physics courses or college courses for the non scientist/engineer?
Reply
When I went to high school (graduating 1990) physics was taught using differentiation and integration in the final 2 years. This matched also what was done in math, which consisted of introductory calculus (functions of one real variable), vector algebra (Euclidean vectors in 2D and 3D), and some rudimentary probability theory. Seeing this mathematics applied does not harm. I don't understand, why you want to avoid calculus in introductory physics, since you have to learn it anyway and from the mathematics lessons it's also known.
In Holland they chose to allow students to choose physics without learning the math modules involving calculus, to increase the number of students choosing physics.
The students who do learn calculus only learn it after we've treated mechanics.
Reply
But again my question: what essential physical (!) concepts and insights do my students miss if I treat mechanics the way I described (i.e. with my version of Newton's laws)? Could you pinpoint that?
They miss the conceptual understanding. Physics conists of both experiments/observations and theory/model building. A purely qualitative collection of empirical facts is at best half of the achievements of physics.
Reply
No-one is talking about a "purely qualitative collection of empirical facts", so this is a strawman argument. We're talking about applications of calculus. That means explicit integration and differentiation.
As I said, we calculate a lot of stuff. Again: for up to constant accelerations we use simple algebra, beyond that we use graphs and geometry like slopes and areas. Yes, if you formalize this stuff you get calculus. But that's not the point. You seem to claim that if you don't formalize this stuff, students will lack in conceptual understanding. I don't get that.
Let me give an explicit example. I throw a ball right up in the air, under the influence of gravity and air resistance (Fair ~v^2). My standard questions then to my students are questions like
- what's the acceleration at the maximum height, and does this depend on air resistance?
- which way will take the longest time, up or down?
- when will the resulting force be the greatest, half-way up, at it's maximum height or half-way down?
I let them sketch h-t and v-t diagrams, compare these diagrams in the case without friction (why does the speed at the beginning equals the speed at the end geometrically?) and we investigate whether such sketches help to answer the questions.
If students can answer these questions in a satisfactory way, I don't see what it would add in their understanding of the underlying physics if these students could also solve Newton's second law for this case, solve a first order differential equation by using separation of variables, perform some nasty algebraic manipulations and an integral and give me the function h(t). In my experience, even students who can perform these calculations don't always give the correct answers to questions like the above. Sure, if they want to study more formal stuff and more complex situations, calculus becomes necessary. But we talked about the understanding of Newton's laws here.
Of course, we also calculate in these situations, with energy conservation, forces and what have you, so of course it's not a matter of "purely qualitative" exposure. Again, that's not the point.
But why not using explicit differentiation and integration in physics? It's taught in mathematics, so why not using it where it's most easy to use?
So you ARE differentiating and integrating. I don't get, why you don't make the step from geometric concepts to just name a slope of a function graph derivative and the area under the function graph an integral. You can very easily motivate this. I don't think that you need the university-level ##\epsilon##-##\delta## formalism in physics but plausible arguments. E.g., you define the derivative of a function, ##f'(x)##, as the slope of the tangent at the point ##(x,f(x))## as the limit of the slopes of secants, i.e.,
$$f'(x)=\lim_{\Delta x \rightarrow 0} \frac{f(x+\Delta x)-f(x)}{\Delta x}.$$
It's very easy to show the linearity of the derivative, the product rule, and the chain rule from this by plausibility arguments, and with this you can use derivative for all purposes needed at high school. Many derivatives of concrete functions can be easily derived just using the definition, e.g.,
$$f(x)=x^n$$
for ##n \in \mathbb{N}##. The students for sure know the binomial formula, from which you get
$$f(x+\Delta x)=x^n + n \Delta x x^{n-1} + \mathcal{O}(\Delta x^2),$$
and plugging this into the definition of the derivative, you immediately get
$$f'(x)=n x^{n-1},$$
etc.
The same with integrals as the area under a function graph. The fundamental theorem of calculus is a one-liner at the level of rigorosity I have in mind, and you have everything you need for integration used in high-school physics.
So why are so many teachers thinking, they make things easier with hiding from their students this simple hands-on use of calculus. It's of course far from rigorous, but in high school nobody expects rigor at university level but just good propaedeutics!
Reply
So what to do if the student does not know calculus or is not taking it: not let them take a physics course because they would not fully appreciate or understand it?
Reply
No, in my case it is not taught in mathematics for all students, and when I cover mechanics in the beginning of their fourth year (age 15), none of them has seen any calculus yet. I also teach two different kinds of levels (pre-university and for the more applied sciences we call "havo" in the Netherlands); the last level students are even less mathematically educated. They will never see an integral or differential equation in their life unless they choose a technical study afterwards.
Well, again, because most students haven't seen it yet, and this is what in teaching we call a cognitive overload. I'm teaching 14-18 year old students with all kinds of different mathematical backgrounds, not university students. It seems like you don't get that.
And no, I am not differentiating and integrating. It is a big step to go from the geometrical visual methods to the usual calculus rules. Not for you, of course, but for the average student. You seem to underestimate that. It's like saying "ah, but your ARE using fibre bundles in your first year university course on electromagnetism! Not rigorously, but you can very easily motivate this!" Yes, very easily for you as the teacher. Not for the students you're teaching.
$$f(x)=x^n$$
etc.
Yes, I know how calculus can be taught informally; I do that sometimes with interested students and I have written material for it. And yes, it is "very easily motivated" if you have studied physics at a university and are used to think mathematically. But the whole point of teaching is to be able to understand how (in my case) young people in the age of 14 to 17/18 think, isn't it? My impression is that you aren't able to descend to the level of the average modern high school student who wants to learn physics. Did you ever teach at high schools? Teach to children who are desparately trying to pass the exams? If I mention these "very easily motivated" concepts of yours (and trust me, every now and then I mention some calculus concepts for half of my public who has seen it), half of them simply quit. It may be "very easy" for you, but you know, your way of thinking, your cognitive skills and your years of experience may give you a limited view on the capabilities of the average person. At least, that's my impression if I read your posts about this subject.
And most of all: You haven't answered my question of #45. Tell me how their understanding of the physics (!) improves in learning this calculus stuff for that particular example. The big question is not if it adds anything, because of course it does. The big question is: is it worth the enormous investment at that very moment (and then I mean not for you, but for the average student)? And do I have to wait until senior year to teach mechanics before my students have learned how to solve (simple!) differential equations and integration?
For a high school teacher, those are the relevant questions. And to be honest, that makes it so hard. I could even say: harder than teaching at a university. If I compare my teaching now with my teaching as a PhD and teaching mathematics at an applied university of mathematics, teaching at university level was peanuts compared to what I do now. I really learned how to teach at high school.
Reply
I think that's rather easygoing because you only explained to me how I could explain calculus to my students (who you don't know) without explaining me why and which physical understanding they miss without this explicit usage of calculus. I think that's one of the core questions in teaching. But whatever you want.
They miss a clear way to express the content of the fundamental laws of physics. It starts from the very beginning with kinematics in Newtonian mechanics: You cannot even formulate what's velocity and acceleration etc. This is not even taking into account the use of calculus to make predictions (like, e.g., Kepler's Laws from Newtonian mechanics and theory of gravitation), which is nearly impossible without calculus (though Newton did hide his calculus also in his Principia, but it's very much more complicated and even more out of reach of high-school students than the use of calculus itself!).
Of course, as teacher at a high school you cannot choose your method of teaching freely but you have to adjust to what's given in the curricula some officials have created. In Germany there are 16 such curriculas with pretty different levels. None is really good in comparison to other European countries, as several studies (like PISA) show. For me the main obstacle is the lack of systematics and the low level of math (but still including calculus!).
Reply
  • Sad
You keep repeating it, but it's obviously wrong. Describing change is not applying calculus. You obviously use a different definition of the term than the usual one. I guess e.g. economics then also can't be taught without calculus, according to your standards/definition.
Reply
It's like watching a boring tennis match :(
Reply
  • Haha
You cannot express velocity other than by the time derivative of the position vector. Everything else makes this issue unnecessarily more complicated. But we argue in circles. Let's just agree to disagree.
Reply
  • Sad
So what is it? Is a definition of velocity without calculus impossible or unnecassarily more complicated (but possible)?
You're contradicting yourself in one single sentence. But sure, whatever you want.
Reply
Yes, you're right, everything has been said.
Reply
In my opinion it's impossible, because after all it's defined by a derivative. I was referring to the "calculus-free ideologists", who claim not to use calculus but define velocity as a limit (of course also without clearly defining what a limit is).
Students learn the concept of rates in middle school. Speed is not a new concept, Flow is not new. Other less physical rates such as inflation etc are attainable. But the rate of change of direction with no change in speed needs work but not with calculus to demonstrate the concept and produce understanding.
Perceptible physical phenomena do not need calculus to be appreciated. Transcendent phenomena, on the other hand, do require a mathematical framework to be appreciated.
To do physics requires all manner of mathematics and only a few attain the facility to do this.
Reply
Wrestling. Steel cage death match!
Reply
  • Love
  • Haha
