How is the inequality |a+b| \leq |a| + |b| proven using different methods?
  • Thread starter Thread starter phospho
    Inequality Proof
5 replies · 2K views
phospho
prove [itex]|a+b| \leq |a| + |b|[/itex]
i've proved it considering all the 4 cases for a and b but the book went about it a different way:
[itex](|a+b|)^2 = (a+b)^2 = a^2 + 2ab + b^2[/itex]
[itex]\leq a^2 + 2|a||b| + b^2[/itex]
[itex]= |a|^2 + 2|a||b| + |b|^2[/itex]
[itex]= (|a|+|b|)^2[/itex]
it then goes on the conclude that [itex]|a+b| \leq |a| + |b|[/itex] because [itex]x^2 \leq y^2[/itex] implies [itex]x < y[/itex]
I don't get there the [itex]\leq[/itex] comes from... nor the conclusion
Should be ##x^2 \leq y^2 \implies x \leq y##.
And it only holds for non-negative ##x## and ##y##. Not a problem here, because in the original proof, you're dealing with absolute quantities which are, by definition, non-negative.
Prove it by bringing the ##y^2## to the LHS, then factorise. What can you conclude?
## x^2 - y^2 \leq 0 ##
## (x+y)(x-y) \leq 0 ##
## -y \leq x \leq y ##
I don't understand what that shows, also I don't this step in their proof:
where did the ## \leq ## sign come from? Also, their proof is for [itex]|a+b| = |a| + |b|[/itex], how does their conclusion make it ## |a+b| \leq |a| + |b| ## ?
thanks
From this step, observe that ##(x+y)## is non-negative (because ##x## and ##y## are both non-negative). Hence you can cancel ##(x+y)## from the LHS and you're left with ##x \leq y## as required.
That allows you to go from ##(|a + b|)^2 \leq (|a| + |b|)^2## to ##|a + b| \leq |a| + |b|##, which is the very thing they are trying to prove.
Basically, that amounts to saying ##ab \leq |a||b|##. The equality holds as long as both a and b have the same sign (either both positive or both negative) or when at least one of them is zero. But if a and b have opposite sign (i.e. one of them is positive, the other is negative), then ##ab < |a||b|## because the LHS will become negative while the RHS is always positive.
So ##ab \leq |a||b|## covers all the possibilities. Multiply that by 2 to get ##2ab \leq 2|a||b|##. Add ##a^2 + b^2## to it to get exactly what they wrote down.
No it isn't and that statement is not even true in general. Why do you think that?
Work through the algebra again. I think you're getting confused because the signs alternate between equal and less-than-equal, then back to equal in a long "chain". I think you should write all the steps down systematically in terms of a single LHS and RHS with only a single sign between them at each step, and see if you can understand it better.
The first [itex]\le[/itex] occurs because, for any numbers [itex]w[/itex], [itex]w \le |w|[/itex]
Next, you have reached the point where you have
[tex] |a+b|^2 \le \left( |a| + |b| \right)^2[/tex]
Everything involved is non-negative because of the absolute values: what happens when you apply square roots?
thank you both... I wrote it down step by step and got it.
