How Is u_alpha an Injective Mapping in Proposition 2.1.4?
  • Context:
  • Thread starter Thread starter Math Amateur
    Modules
4 replies · 2K views
Math Amateur
MHB
I am reading Paul E. Bland's book: Rings and Their Modules and am currently focused on Section 2.1 Direct Products and Direct Sums ... ...
I need help with some aspects of the proof of Proposition 2.1.4 ...
Proposition 2.1.4 and its proof read as follows:View attachment 8039
In the above proof by Paul Bland we read the following:
" ... ... Since $$p_\alpha u_\alpha = \text{ id}_{ M_\alpha }$$, we have that $$u_\alpha$$ is an injective mapping and that $$p_\alpha$$ is surjective ... ... "Can someone please explain exactly how/why $$u_\alpha$$ is an injective mapping ... ?Help will be appreciated ...
Peter
How do you prove that an $R$-map in injective? Make a start with the proof that $u_\alpha$ is injective.
Hi Steenis ...
To show that $$u_\alpha$$ is injective ...
... we assume that $$u_\alpha (a) = u_\alpha (b)$$ ...
... then we need to show that $$a = b$$ ...So ... let $$u_\alpha (a) = u_\alpha (b)$$ ... Now $$p_\alpha u_\alpha = \text{id}_{ M_\alpha }$$ ...
... so ... $$p_\alpha u_\alpha (a) = \text{id}_{ M_\alpha } (a) = a$$ ... ... ... ... (1)
... and ... $$p_\alpha u_\alpha (b) = \text{id}_{ M_\alpha } (b) = b$$ ... ... ... ... (2)... and we also have $$p_\alpha^{ -1} p_\alpha u_\alpha (a) = p_\alpha^{ -1} \text{id}_{ M_\alpha } (a) = p_\alpha^{ -1} ( a )
$$\Longrightarrow u_\alpha (a) = p_\alpha^{ -1} ( a )
$$... and similarly we have ... $$u_\alpha (b) = p_\alpha^{ -1} ( b )$$
... ... do not seem to be progressing toward objective of demonstrating that $$a = b$$ ...
Can you help?
Peter***EDIT***oh! ... (1) and (2) and our assumption give us the answer ...Putting $$u_\alpha (b) = u_\alpha (a)$$ into (2) gives
$$ p_\alpha u_\alpha (b) = p_\alpha u_\alpha (a) = a = \text{id}_{ M_\alpha } (b) = b$$
and QED!
Is that correct ...?
Peter
YES, that is correct.
There is a more general rule:
Let $A$, $B$, and $C$ be sets, and $f:A \longrightarrow B$, $g:B \longrightarrow C$, and $h=g \circ f:A \longrightarrow C$ (set-) functions, then if $h$ is bijective then $g$ is surjective and $f$ is injective.
This also applies to $R$-maps:
$A$, $B$, and $C$ are $R$-modules, $f:A \longrightarrow B$, $g:B \longrightarrow C$, and $h=g \circ f:A \longrightarrow C$ are $R$-maps, then if $h$ is an isomorphism, then $g$ is an epimorphism and $f$ is an monomorphism.
The proofs are little different than your proof, but easy, you can try it.
Thanks Steenis ...
Peter
