How Long Is the Piano String for the 3rd Harmonic?
The discussion centers on calculating the length of a piano string for the 3rd harmonic, which corresponds to a wavelength of 45 cm. The string's length can be determined by understanding that the third harmonic has three antinodes, leading to the formula where three half wavelengths equal the string length. Specifically, three half wavelengths amount to 67.5 cm. Participants emphasize using drawings to visualize the harmonics and suggest that no complex formulas are necessary for the calculation. The final calculated length of the string is 67.5 cm.
xuhhad
The 3rd harmonic on a piano string occurs when a 45.0 cm wave is produced. How long is the string.
This question is really confusing can i get some leads to help me out please and thank u
Make three drawings showing a string vibrating at the first, second and third harmonic.
Hint: Third harmonic has three antinodes.
http://en.wikipedia.org/wiki/Vibrating_string
Mark the wave length on the drawing of the third harmonic.
http://en.wikipedia.org/wiki/Wavelength
The question is presumably telling you that one wavelength is 45cm.
Apply basic maths to calculate the length of the string.
I'll let you work it out but I make the answer a number between 60cm and 70cm.
OK i understand but i still don't no what formula to use.
No formula is required. Scale from the drawing.
One wave length = two half wave lengths = 45cm
So three half wave lengths = 3/2 * 45cm = 67.5cm
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
