How many arcseconds does Sun travel through sky?
  • Context: High School
  • Thread starter Thread starter MarkB7
    Sky Sun Travel
The discussion revolves around the question of how many arcseconds the Sun appears to travel through the sky in one tropical year, considering different reference frames and the implications of Earth's rotation and orbit.
  • Mark asks how many arcseconds the Sun travels in one tropical year, suggesting it must be a significant amount.
  • Some participants clarify that the apparent motion of the Sun is influenced by Earth's rotation and orbit, leading to confusion about the reference frame.
  • One participant explains that from an Earth-centered inertial frame, the Sun's apparent travel is slightly less than 360 degrees due to the precession of Earth's axis, amounting to about 50 arcseconds.
  • Mark specifies that he is interested in the apparent travel of the Sun from the vernal equinox to the next vernal equinox.
  • Another participant questions the usefulness of standing on Earth as a reference frame, suggesting it leads to confusion.
  • Mark calculates the apparent travel of the Sun as approximately 1296000 arcseconds per day, leading to a yearly total of 473040000 arcseconds from his perspective on Earth.
  • Participants note that while Mark's calculations reflect his perspective, they do not represent the Sun's actual motion relative to the stars.
  • There is a reiteration that the Sun moves 360 degrees a year relative to fixed stars, contrasting with Mark's calculations based on his standing position.
  • Mark seeks confirmation of his calculations regarding the tropical year and day in terms of arcseconds.
Participants do not reach a consensus on the question, with multiple competing views regarding the reference frames and the interpretation of the Sun's apparent motion.
There are unresolved issues regarding the definitions of reference frames and the implications of Earth's rotation and orbital motion on the perceived travel of the Sun.
MarkB7
Hi Everyone,
I have a simple question:
How many arcseconds does the sun "travel" through the sky in one Tropical Year?
Mark
Astronomy news on Phys.org
Mark, you are trying to resurrect a closed thread. It was closed for a reason.
From the perspective of an Earth-centered inertial frame, the answer is a tiny bit (about 50 arcseconds) less than 360 degrees.
Hi D H,
I'm not resurrecting that thread. I just hope we can come to a consensus on the number.
I mean all the travel of the sun in a year. So it's got to be a lot.
Mark
Mark, you are still confusing the Earth's daily rotation with the Earth's orbit. This is the sole source of your confusion. Imagine what things look like from a reference frame that is not rotating with respect to the remote stars and with origin at the solar system barycenter. The International Celestial Reference Frame, for example. The Earth-Moon barycenter follows a nearly elliptical path in this frame. The time it takes for the Earth-Moon system to complete one orbit in this frame is one sidereal year.
Now flip your point of view to an Earth-centered frame, but keep the same axes. This is an Earth-centered inertial frame (a bit of a misnomer; this is an accelerating but non-rotating frame). From this perspective, it is the Sun that completes one orbit about the Earth in one sidereal year.
What about a tropical year? The Earth's rotation axis is tilted with respect to the Earth's orbital angular momentum vector. Suppose the only bodies in the universe were the Sun and Earth (i.e., no Moon or Jupiter to confuse things) and suppose the Earth's rotation axis was unchanging. With these simplifying assumptions, the line connecting the Earth and the Sun would lie completely on the ecliptic plane twice a sidereal year -- and those equinoctal points would be fixed points in the solar system barycentric frame. The between successive vernal equinoxes, the tropical year, would be one sidereal year.
The Earth's rotational axis is not constant; it instead undergoes a slow precession. Because of this precession, a tropical year is a bit shorter (~20.5 minutes) than a sidereal year. Given that a full orbit (one sidereal year) is 360 degrees by definition, 20.5 minutes corresponds to about 50 arcseconds.
Hi DH,
I think you misunderstand my intention here. I simply want to find out how many arcseconds the Sun travels through the sky in one year.
You are the one continuing the conversation from the closed thread.
Mark
What year (tropical, sidereal, anomalistic), and what reference frame (Earth centered inertial or Earth-centered, Earth-fixed)?
Hi DH,
Thank you! I'm sure you're a nice person : )
So, by tropical year I mean the amount of arcseconds the sun travels from the spot over the vernal equinox to that same spot over the vernal equinox the next year. Of course it doesn't travel, so, apparent travel.
Mark : )
Dang! Rotation with respect to what frame of reference? Do you understand what this question means?
Ummm. Assume we are standing on the Earth and looking up...all year.
That is not a very useful frame of reference. It is just going to lead you to confusion -- and that is exactly what is going on. Forget that frame. Read post #4.
Let's approximate...
365 days * (3,600sec/day) = 13,140,000A very boring analysis
Thank you for responding to my question!
3,600 arcseconds per day?
I think it's 1296000 arcseconds per day.
So then it would be, approximately, 1296000 x 365?
Mark
Yes, the Sun would travel approximately 1296000 x 365 arcseconds a year if you stood on Earth looking up. (It doesn't actually, but let's clear up one issue at a time.) This does NOT mean the Sun moves 1296000 x 365 arcseconds a year relative to the stars.
Do you understand the difference? Suppose I put you on a merry-go-round and start spinning it at one revolution per second. To you, it would appear that the Sun is moving 360 degrees per second. This is analogous to the 1296000 x 365 arcseconds the Sun moves a year. However, the Sun doesn't move 360 degrees per second relative to the fixed stars; it moves 360 degrees a year, whether you're on a merry-go-round or on the ground.
You are correct. That would be a lot of difference.
I assume you mean 360 degrees per day from the reference frame of standing on one spot of the Earth. Every day, from my reference frame, the sun circles me 360 degrees.
So, can we say the sun travels 473040000 arcseconds every year from our reference frame? Standing in one spot on the solid earth? I think this is the right answer. We see the sun once, twice, 365 times and back to the same spot, making 473040000 arcseconds of angle.
Mark
This is really all that I wanted to come to in this thread: how many arcseconds the sun travels in one year from the reference point of a person standing on one spot of the solid Earth.
Tropical Year: 473040000 arcseconds
Tropical Day: 1296000 arcseconds
I want to be sure about this, so please post if you think it is incorrect.
Mark
I'm afraid you are. Thread closed.
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 49 ·
13K
  • · Replies 56 ·
