How much work can be realized? Simple physics I can't understand.
  • Thread starter Thread starter fixedglare
    Physics Work
6 replies · 2K views
fixedglare
To be able to break cement, the hammer of a machine needs to have a mass of 1.00 x 10² kg.
The motor of the machine lifts it at a height of 5.00 meters every 10.0 seconds.
a) How much work did the machine realize within 1.00 minute?
W = Fd
1 min = 60s/1min
Work = 100 kg * 5.00 m = 500 J
60 seconds * 500 J = 30000 J
Is that how its done? I'm pretty confused.
You have the right idea. The first part:
is the work done in lifting the block 5.00m, and the problem tells it lifts the hammer 5.00m in 10.0s, so you can also say that's the work done in 10.0s. Then, since the answer needs to be the work done over a full minute, you just have to make the conversion from work done in 10.0s to work done in one minute.
jackarms said:
You have the right idea. The first part: is the work done in lifting the block 5.00m, and the problem tells it lifts the hammer 5.00m in 10.0s, so you can also say that's the work done in 10.0s. Then, since the answer needs to be the work done over a full minute, you just have to make the conversion from work done in 10.0s to work done in one minute.
So, 500 J * 60 seconds = 30000 s
then
30000 s * 1 min /60 s?
'Couple of comments:
1.00 × 102 kg is the hammer's mass, not its weight. Weight is the measure of force. :smile:
The hammer is raised once every 10 seconds (not every second, but once every 10 seconds). So how many times is the hammer raised in a minute?
No, you're mixing up your units. What you have is this:$$500J \cdot \frac{1}{10s}$$That's the work done per second, or the rate at which work is done. Then you have find the work done in a full minute. That means using this relationship:$$ amount = rate \cdot time$$
Or, just make a proportion:$$\frac{500J}{10s} = \frac{?}{1min}$$, where [itex]?[/itex] is the amount of work you're looking for.
EDIT: Yes, what collinsmark said. That 500J needs to be recalculated using weight instead of mass.
Weight = 1.00 x 10 2 kg * 9.81 m/s = 981 N
Work = 981 N * 5.00 m = 4905 J
in 1 minute the hammer realizes 6 * 4905 J = 29430 J?
There you go. :approve: That looks right to me. :smile:
