How Much Does High-Speed Flight Affect Aging?
  • Context: Undergrad
  • Thread starter Thread starter Beneer
The discussion centers on the effects of high-speed flight on aging, specifically for airline pilots. Ben, an airline pilot, inquires about the time dilation effect from flying 20,000 hours at an average speed of 400 knots. Buzz calculates that Ben would be approximately 64 microseconds younger than his ground-based colleagues upon retirement. Participants confirm that while gravity and velocity influence time dilation, the overall effect is negligible.
  • Understanding of time dilation principles
  • Basic knowledge of physics related to velocity and gravity
  • Familiarity with the theory of relativity
  • Awareness of aviation metrics such as flight hours and speed
  • Research Einstein's theory of relativity and its implications on time dilation
  • Explore the effects of gravity on time as described in general relativity
  • Learn about practical applications of time dilation in aviation and GPS technology
  • Investigate the impact of high-speed travel on biological aging
Aerospace engineers, airline pilots, physicists, and anyone interested in the intersection of aviation and relativistic physics.
Beneer
Hello all, hope you are well. A quick question. I'm employed as an airline pilot. If I fly for 20000 hours over my career at an average speed of 400 knots (roughly 200 m/s), how much younger would I be than my ground based colleagues upon retirement ? Kind regards, Ben
Hi Ben:
I calculate that you will be 64 microseconds (64 × 10-6 seconds) younger.
Regards,
Buzz
As I recall, it depends on the direction you travel because traveling with the Earth's rotation is different than traveling against it. If you assume all trips are mirror images then you have to do 2 computations and add the results.
It is in any case, as Buzz has computed, an utterly trivial amount (even if he is off by a bit because of what I said)
Gravity and velocity both play a role, don't they? And fight each other in this case, iirc.
Yeah: https://en.m.wikipedia.org/wiki/Time_dilation
I'm not sure which would win out at the crusing speed and altitude of commercial aircraft, but like above it is pretty trivial.
They do, and that's a good point, although as you also note, that doesn't change the conclusion that in any case it is a trivial amount. What you've pointed out, in fact, makes it even more trivial.
Thanks everyone for your responses - thought it would be a trivial amount (didn't realize how trivial...) - warm regards, Ben
  • · Replies 32 ·
