How Should Negative Improvement Be Recorded in Pre-Post Test Data Analysis?
  • Level: Undergrad
  • Thread starter Thread starter craig100
    Test
1 reply · 4K views
craig100
Hello There,
I'm after a little advice; I have data collected during experimentation that was designed to determine the improvement of two groups of subjects between a pre and a post-test. The results are as follows:
Pre & Post test numbers represent the number of errors made
Group 1:
Code:
Pre|Post|Improvement
0	0	0
1	0	1
5	4	1
12	0	12
2	0	2
7	6	1
0	0	0
13	0	13
Group 2:
Code:
0	1	-1
2	0	2
1	0	1
0	0	0
0	11	-11
5	23	-18
I'm applying the t-test to determine if there is a statistical difference between the means(of the improvement columns).
My question is really simple(hopefully)... in group 2, should I be recording improvement as a negative number? or simply zero?
Using zero will not give me a significant statistical difference between the means of group 1 and group 2... using the negative numbers does.
Also, if I'm keeping the negative improvement numbers, is it okay to represent improvement as a negative percentage?
I've not done much with statistics, so would appreciate your input.
Thanks,
Craig.
craig100 said:
Hello There,
Group 1:
Code:
0	0	0
1	0	1
5	4	1
12	0	12
2	0	2
7	6	1
0	0	0
13	0	13
Group 2:
Code:
0	1	-1
2	0	2
1	0	1
0	0	0
0	11	-11
5	23	-18
Thanks,
Craig.
Since you are subtracting in the order Pre-Post, a negative difference indicates a higher value in the post data - that's what you are hoping to find, if I understand you correctly.
Note that you are free to subtract in either order: if the negative differences are giving you a conceptual problem, subtract in the other order.
I would be more concerned about doing t-tests with such small samples.
