High School Understanding Quartiles: Different Methods for Calculating and Their Purpose
  • Thread starter Thread starter songoku
Calculating quartiles can yield different results depending on the method used, as demonstrated by contrasting manual calculations and a teacher's guidance. The manual method involves finding the median and then determining the middle of the upper data, while the teacher's method uses a formula based on the total number of data points. Both approaches are valid, leading to different quartile values. This raises questions about the significance of quartiles if various methods produce different results. Ultimately, understanding quartiles is important for data analysis, as they provide insights into data distribution, regardless of the calculation method.
songoku
TL;DR
Let say I have 21 data, from 1 to 21
What is the upper quartile?
If I do it manually, this is what I do:
1) find the median (which is 11)
2) find the middle data of the "upper data" (data to the right of median), which will be the middle between 16th and 17th data:
$$\frac{16+17}{2}=16.5$$But I got this note from my teacher:
Using that method:
1) find ##\frac 3 4## of n, which is 15.75
2) round up ##\frac{3}{4}n## , which is 16
3) pick 16th data, which is 16I get two different results. Which one is correct?
Thanks
This Wikipedia page describes four different ways to calculate quartiles.
So all methods are correct eventhough the results are different? If yes, it means that the value of the quartiles are not really important, so what is the purpose of finding quartiles?
Thanks
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
