How to calculate the stiffness of an arch?
  • Thread starter Thread starter DyslexicHobo
    Stiffness
This discussion focuses on calculating the stiffness of an arch subjected to a load at its vertex. The user seeks a first-order estimate for stiffness modeling, emphasizing that traditional solid mechanics equations do not apply directly to arch analysis. The conversation highlights the importance of considering the second moment of area and utilizing the formula P/delta = (192EI)/(L^3) for a curved beam with a central load. Additionally, the user is learning to use COMSOL for more advanced modeling.
  • Understanding of arch mechanics and statically indeterminate structures
  • Familiarity with the second moment of area and its significance in stiffness calculations
  • Basic knowledge of beam theory and load distribution
  • Experience with finite element analysis software, specifically COMSOL
  • Research the application of the Wilson and Quereau correction factors in beam analysis
  • Learn how to calculate the second moment of area for various cross-sections
  • Explore COMSOL tutorials focused on structural analysis of arches and beams
  • Study the differences between arch and beam behavior under load
Structural engineers, mechanical engineers, and students involved in arch design and analysis, particularly those seeking to understand stiffness modeling and finite element analysis techniques.
DyslexicHobo
Hi all,
I'm trying to design an arch for a project (will be about 4" long). This arch will be experiencing a load on its vertex, and I need to make sure that the arch will not deform very much.
What is a good way to model the stiffness of an arch like this? As far as I know, there is no fundamental solid mechanics equations that I can use for this, and I don't know how to use any finite elements software very well.
Any tips on how to model this?
Thanks.
Edit: Link to sketch of arch. I'm looking for the simplest first-order estimate that would be more accurate than modeling it as just a square simply supported beam.
The strength and stiffness of an arch depends upon the strength and stiffness of its abutments.
Arch analysis does not have a closed form solution, like beam analysis.
So you will need to provide more information for more help - there is nothing like a good sketch.
Here is a general sketch of how I was planning on designing the beam.
The dimensions are not set in stone, and I realize the current geometry is far too complicated to model mathematically. I'm trying to learn how to use COMSOL, but until then I'd like at least a first-order estimate.
Thank you.http://yfrog.com/nabeamsketchrev01ap
Picture: http://yfrog.com/nabeamsketchrev01ap
Is this a beam with a curved soffit or is it an arch?
In other words how is is supported?
On the 0.5 x 0.25 pads on the bottom at the ends?
If it is really just a curved beam there are some references for curved beams here
https://www.physicsforums.com/showthread.php?p=2788414
You could apply the Wilson and Quereau correction factors to a standard beam analysis.
I'd like to model it as a 2-dimensional analysis if possible. If that's possible, one end is going to be constrained in all axes (x and y, as well as moments about x and y). The other end will be constrained in only the y-direction, but the moments will be constrained in both directions simply due to the geometry I chose (flat surface instead of a "pin").
All of the analysis in my solid mechanics book that I found shows "simply supported" beams (one end is a "pin" connection that constrains movement translationally, but does not provide reactionary moments. the other end is a "roller" which constrains movement translationally in only the y-direction).
Also, would estimating the second moment of area be useful here?
Bottom line: I'm looking for a simple first-order approximation of beam stiffness. How would I calculate the stiffness of an arch with a rectangular cross-section? I feel like that would be the place to start.
So what I think I'm going to do is try to find the second moment of area and plug it into the equation: P/delta = (48*E*I)/L^3
Where P/delta would be the stiffness. Now I just need to figure out how to find the second moment of area easily.
It would help yourself and others enormously if you revised your terminology.
An arch is a compression structure that does not carry moment.
It converts a horizontal load to horizontal and vertical force reactions at its abutments. Because there are both reactions at both abutments it is statically indeterminate.
But, from what you have said, you are considering a restrained or constrained (curved) beam.
This has vertical reactions and moments at its abutments, but not horizontal ones.
The appropriate formula for such a beam with a single central load is
\frac{P}{\delta } = \frac{{192EI}}{{{L^3}}}
You should look this up if you do not know it.
Your beam is quite close to flat so the correction factor, K for the curvature will be close to unity.
24K
