How to construct the decoding function β for Gödel numbered sequences
  • Level: Graduate
  • Thread starter nomadreid
    Godel Sequences
2 replies · 3K views · last reply
nomadreid
First, this is not the same question as
https://www.physicsforums.com/threads/goedel-numbering-decoding.484898/
It concerns a different encoding procedure, hence a different decoding one.
My question concerns the argument in http://en.wikipedia.org/wiki/Gödel_numbering_for_sequences
for the existence of an effective decoding function β corresponding to the effective coding π for the Gödel number for sequences as given in that article : that is, given this procedure for generating the Gödel number from a sequence, and given the Godel number G of an unknown sequence (k1,...kn), to prove the existence of β such that for all for all 0<i<n, β(G,i) =ki.
Wikipedia leaves the " for all 0<i<n " implicit, so I will follow that abuse of notation as well:
If I understand that argument correctly:
First, we assume that we can choose misuch that
[*] mi>ai
[**] all mi are coprime to one another.
(This can even be done constructively.)
Then since we know that (k1,...kn) exists, we know that a least solution x to the congruences
x ≡ ai mod mi
exists. Call it X.
We can construct a recursive function rem(a,b) so that rem(a,b)=(a mod b), so since we know X exists, we know that a procedure rem(X,mi) = ai exists.
OK, something rankles. Apparently I am not laying down the outline correctly , because it sounds slightly circular to me. Can anyone tell me what is wrong in my summary?
(It would be nice if there were a constructive proof...)
(Also: the construction of the miso as to fulfill [*] and [**] would seem to require rather huge numbers: if [*] is fulfilled, then one just takes m = lcm(1,..., n-1) and mi= (i+1)*m + 1. But the only way I can see to make sure that [*] is fulfilled is to set m = lcm(1,...n-1, G), where G is the given Gödel number of the sequence; this ends up with rather large mi, so would it still be effective?)
I moved this thread from the Computer Science/Programming section to here. I think this forum section is a better fit.
Thanks for the actions, Greg Bernhardt and Mark 44. Let me state the question a bit better, including correcting a couple of mistakes in my original post.
In showing the existence of an effective Gödel numbering for sequences, Wikipedia:
in one direction: it takes a known sequence (a1,...an) and establishes a coding procedure which ends up with the Gödel number a ( no problem so far).
Then, to show that a decoding procedure β exists so that β(a,i) = ai : here's where it gets a bit confusing.
[1] First it finds m such that m is divisible by all the non-zero indices, and then:
[2] constructs a sequence of pairwise coprime numbers mi
[3] using the CRT (Chinese Remainder Theorem] it shows that, using a pairing function π, that π(x0,m) = a, whereby x0 satisfies the system of equations x0 ≡ aimod mi, so that rem(x0,mi) = ai.
By now I am totally lost. Therefore I presume that I have laid out the general argument incorrectly. Could someone either correct this or direct me to a website which lays out the argument a bit more clearly than Wikipedia does? (Yes, I know I can "just" google it, but I didn't come up with anything.)
