How to deal with the index in Einstein summation?
The discussion focuses on expressing the invariance of a matrix U under Lorentz transformation using Einstein summation notation. Participants clarify the correct way to balance indices in tensor equations, emphasizing that both sides must have matching free indices. The notation is refined to indicate the transformation clearly, with suggestions to use primed indices for clarity. The importance of the Kronecker delta as an index-substitution operator is highlighted, aiding in understanding tensor transformations. Ultimately, the correct expression for the invariance of U is confirmed as balanced, demonstrating a successful resolution to the initial confusion.
yukcream
Given U^k_i, the components of U is a delta function i.e for i=k U^i_k =1,
to prove it is invariant under Lorentz transformation~~
I don't know how to express it in Einstein summation notation, I am very confused with the upper-lower index, is it right to write the transformation in this?
U'^k_i = T^i_m T^n_k U^k_i ? where T is the Lorentz transformation~~
yukyuk
yukyuk
Not exactly. What you have is:
U'^k{}_i = T^i{}_m T^n{}_k U^k{}_i
better, but still not right would be:
U'^n{}_m = T^i{}_m T^n{}_k U^k{}_i
This balances the indices. Note that after summation, the i's and k's will disappear. In that case, the n's and m's will be the same on both sides of the equation. This balance of indices is what you are aiming for.
The problem with this notation is that you can't tell the difference between the two T's. I recommend the following notation which brings out that difference:
U^{n'}{}_{m'} = T^i{}_{m'} T^{n'}{}_k U^k{}_i
Notice that I took the prime off of the tensor U and put it on the indices. There is a lot of justification for this. This notation indicates what you are doing, you are expressing the same tensor in different coordinates.
I also think that this notation lays bare the solution to the problem.
By the way, your description of the delta 'function' is incomplete. You have:
for i = k \ U^i{}_k = 1
but what you should have is:
for i = k \ U^i{}_k = 1 and for i \ne k \ U^i{}_k = 0
U'^k_i = T^i_m T^n_k U^k_i is not correct because the "free indices" aren't the same on both side... on the left it's \blacksquare^k_i whereas it is \blacksquare^n_m on the right.
The correct form is
U'^n{}_m= T^i{}_m T^n{}_k U^k{}_i (where each side has \blacksquare^n{}_m )
As jimmysnyder suggests, for these coordinate transformations, it may be better to use these primed- and unprimed-indices.
This may help (and I'll use the standard \delta^a{}_b as the Kronecker delta). The Kronecker delta acts like an "index-substitution operator":
Q^a=\delta^a{}_bQ^b, which "substitutes a for b".
Q^a{}_b=\delta^a{}_m\delta^n{}_bQ^m{}_n, which "substitutes a for m, and b for n".
Try googling "index gymnastics" tensor
http://mathworld.wolfram.com/IndexGymnastics.html
Working with tensors made more sense to me after I was introduced to the "abstract index notation"
See http://en.wikipedia.org/wiki/Abstract_index_notation http://www.ima.umn.edu/nr/abstracts/arnold/einstein-intro.pdf
I want to prove that the given martix
U^k{}_i
is invariant under Lorentz transformation~ am I correct to prove in following way?
Express U in delta as its really a delta function~
\delta'^k{}_i=T^i{}_mT^n{}_k\delta^m{}_n
\delta'^k{}_i=T^i{}_mT^m{}_k so
=\delta^k{}_i
You both help me a lot and the article linked is very useful thanks :smile:
yukyuk
This equation is not balanced in the sense that I described to you. Can you try this a second time? To determine if an equation is balanced, perform the following steps:
1. Start with the equation in question:
2. From each side of the equation, eliminate summation indices:
\delta'^k{}_i=T^iT_k\delta
3. Look at the list of superscripted indices on the left and right of the equal sign:
k on the left, i on the right
4. If they are not the same, the equation is not balanced. In that case, stop right here, redo the equation and start again with step 1. If you pass this test, go on to step 5.
5. Look at the list of subscripted indices on the left and right of the equal sign:
i on the left, k on the right
6. If they are not the same, the equation is not balanced. In that case, stop right here, redo the equation and start again with step 1. If you pass this test, then the equation is balanced.
O~~~~I get it :biggrin:
The correct answer is this, right?
\delta^{i'}_{k'}=T^{i'}_{m}T^{n}_{k'}\delta^{m}_{n}
\delta^{i'}_{k'}=T^{i'}_{m}T^{m}_{k'}=\delta^{i'}_{k'}
This time the indices on both side is balance?!
thank you very much~~~
yukyuk
yukcream said:
right?
Right!
Extra text added to satisfy an unnecessary criterion.
  • · Replies 22 ·
