How to determine whether there is a reaction?
  • Thread starter DrOnline
    Reaction
DrOnline
Which of the following combinations (in water) causes a reaction? Write a balanced reaction equation for the cases that cause reaction:
CU2+ + H2(g)
Fe2+ + AG
Fe3+ + Sn2+
etc...
Not applicable.
I've searched quite a bit, but every youtube video I find, and every site I find, explain how to analyze which TYPE of reaction we're dealing with, based on knowing both the reactants and the products.
My task doesn't reveal the product. I need to figure that out. And that's what I need help with.
A: These elements will synthesize if one is an anion and the other is a cation. I count up the charges and balance the equation accordingly. Is this correct? Is that all there is to it?
B: What is the significance of the water, and why is the water not in the list of reactants?
I've been reading http://misterguch.brinkster.net/6typesofchemicalrxn.html, but it doesn't explain how to figure out what products are formed.
Help would be very much appreciated!
What are some reactions (in solution) that you know about?
Compare.
A. that is pretty much correct.
B. well Cu is normally a solid - the fact you are told that it is in a solution tells you something about what form it takes. How do things dissolve in water? Why do some things dissolve and not others?
In your experience of chemistry so far, how has the presence of the water been important to the reactions you have done with chemical solutions?
This exercise is about making links between different experiences and knowledge. People won't always tell you an exact process to solve each particular problem - you are supposed to make the connections.
