Graduate How to Optimize Predictive Models: Include Interactions or Not?
  • Thread starter Thread starter FallenApple
    Prediction
This discussion focuses on optimizing predictive models by determining whether to include interaction terms alongside main effects. The recommended approach involves using stepwise AIC for model selection, but emphasizes the superiority of k-fold cross-validation for evaluating predictive performance. The full model should include all variables and their interactions, and techniques like elastic-net regression can be employed to prevent overfitting while automatically selecting relevant variables. The R package glmnet is highlighted for its ability to perform these tasks efficiently.
  • Understanding of predictive modeling concepts
  • Familiarity with AIC (Akaike Information Criterion)
  • Knowledge of cross-validation techniques, particularly k-fold
  • Proficiency in R programming and usage of the glmnet package
  • Research the implementation of k-fold cross-validation in R
  • Explore the principles of elastic-net regression and its applications
  • Learn about the glmnet package and its functionalities for model selection
  • Investigate the impact of interaction terms on predictive accuracy in regression models
Data scientists, statisticians, and machine learning practitioners focused on enhancing predictive model performance through advanced regression techniques and model evaluation strategies.
FallenApple
So say I want to predict the next point in the data.(or outside since its prediction)
So first, I would include all the variables inside the dataset into the initial model. Then I would use stepwise AIC to iteratively reduce the model down to the final model with minimum AIC. ( I can do this because I do not care about causal explanation, just about prediction)
Now, should the large model consist of just sums of the variables, or should it also include all possible combinations of interactions as well?
Finally, what do I with the final model? Do I just interpret the estimates and confidence intervals as usual?
If you want to do prediction, why use AIC? Why not evaluate prediction error directly? Cross-validation is what you want. Just compare all the models you're interested in and choose the one with the best predictive performance. The AIC is actually asymptotically equivalent to leave-one-out cross validation, but LOO-CV has weird properties, so go with something like k-fold cross-validation.
Likes FallenApple
Got it.
But what if I don't have any models in mind?
Then should I just take a combination of each possibility? For example, say I want to predict y and my data set has x1,x2,x3. Then complete model with everything in it is y=x1+x2+x3+x1*x2+x1*x3+x3*x2+x1*x2*x3. That is the complete model. Then whatever valid algorithm should be able to spit out the subset that best predicts y.
What if I have some models in mind from knowledge of the science? Then would that influence my choice for the prediction?
This is actually a bit of a tricky question. The simplest approach would be to just compare all possible models and select the best one, which would be 2^7 = 128 models in your case, which might take a while if you have to code them manually.
If you want to try something a little more sophisticated, my general approach to these kinds of problems is to fit the full model (with all variables and all interactions) and put a penalty on the model which will help to prevent overfitting and automatically select which variables should be included. For example, elastic-net regression is a modified version of ordinary least-squares regression which shrinks the coefficients towards zero (which tends to help avoid overfitting and increase predictive power) and has the power to set some coefficients to exactly zero, in some sense "automatically" removing variables which do not contribute to the model. If you're comfortable with R, there are several packages which will do this, included glmnet:
https://web.stanford.edu/~hastie/glmnet/glmnet_alpha.html
The package, handily, can also do cross validation automatically. The above link includes a tutorial.
Likes FallenApple
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
