How to draw the function x+5<7
  • Context: High School
  • Thread starter Thread starter Manula
    Function
The discussion revolves around how to graph the inequality x + 5 < 7 and whether it can be considered a function. Participants explore the implications of the inequality and its representation on a Cartesian plane versus a number line.
  • One participant questions whether x + 5 < 7 qualifies as a valid function based on the definition of a function.
  • Another participant clarifies that the expression is an inequality, not a function.
  • It is noted that if the inequality involves only one variable, it should be graphed on a number line, while two-variable inequalities can be graphed on a Cartesian plane.
  • A participant describes how to graph the corresponding equation x + 5 = 7, stating it results in a vertical line at x = 2, with the solution set for the inequality being all points to the left of this line.
  • There is a reiteration of the previous point about graphing the inequality, emphasizing the vertical line at x = 2.
  • Another participant raises the question of whether graphing y = (x + 5) would yield different results, suggesting that it might not impose restrictions on the y-coordinate.
  • A later reply agrees that graphing y = (x + 5) would indeed yield different results, as the original inequality does not restrict the y-coordinate in the (x, y) coordinate pairs.
Participants express differing views on whether the inequality can be considered a function and how to appropriately graph it. There is no consensus on the implications of graphing y = (x + 5) versus the inequality itself.
The discussion does not resolve the definitions and implications of functions versus inequalities, nor does it clarify the conditions under which each representation is valid.
Manula
I am just interested in knowing, how to draw the function x+5<7 in a cartesian plane.
Since the definition of a function is, If For a certain input, there exist an out, then it is a function.
Is x+5<7 is a valid function then?
Mathematics news on Phys.org
What you wrote is an inequality, not a function.
If the inequality has only one variable (as yours does), you would graph the solution on a number line. If the inequality has two variables (x and y), then you could graph the solution on a Cartesian plane.
To draw a graph of this inequality, first draw the graph of the corresponding equation. x+ 5= 7. That. of course, is the same as "x= 2". It's graph, in a two dimensional "xy" graph, is the vertical line at x= 2. The set of points for which x+ 5< 7 is the set of points for which x< 2. That is, all points to the left of that vertical line.
But if we take y=(x+5) and then, draw the graph, wouldn't it give different results??
True.
Of the simple reason that the first inequality does not place any sort of restrictions on the y-coordinate in the points' (x,y) coordinate pairs.
  • · Replies 171 ·
11K
  • · Replies 51 ·
