Undergrad Why Does Light Reflect Differently on Leaves in Certain Areas?
  • Thread starter Thread starter pixel
    Color Explain
The discussion centers on the observation of a color effect on leaves, where illuminated areas appeared pinkish in a shaded spot, contrasting with their expected appearance. The phenomenon is not attributed to typical optical effects like thin film interference or diffraction, as the leaves looked white from one angle and pink from another. Participants question why this color change was localized to a small area despite similar lighting conditions affecting other leaves. The complexity of biological interactions is acknowledged, suggesting that external factors, such as animal activity, could influence the observed coloration. Further experimentation is deemed necessary to draw definitive conclusions about the cause of this effect.
pixel
I was walking outside this morning and saw an interesting color effect in the ground cover. Parts of some leaves were illuminated by the sun and looked as expected (left side of image) but when I walked a bit further down and looked back the illuminated areas appeared pinkish (right side of image). The effect only showed up in one small area of the ground cover that was in the shade of a nearby bush. How to explain?
Note that there wasn't a series of colors as you would expect from thin film interference or some type of diffraction effect. The leaves appeared white from one direction and pink from another.
JalTc7s4EkWppCnknXbYadO0lMuLH0jhZcK_RMP-9-3YNaIbDFubNyJWmbJdJkYov8n3BMb56iWZQg=w1280-h800-no.jpg
Likes .Scott
You showed me the first link in my previous color effect post (about black sharpie pen ink reflecting orange). But if that is the explanation here, then why was the effect limited to a small area of ground cover when many other leaves were being illuminated and viewed at similar angles?
Biology is complex. Without further experiments impossible to say more. Maybe an animal peed on those particular leaves or whatever.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
12K
14K
  • · Replies 21 ·
13K
