How to find function with given roots and point
The problem involves finding a quadratic function with specified x-intercepts at -2 and 2, and that passes through the point (0, 8). Participants are exploring how to derive the function given these conditions.
  • Participants discuss substituting known values into the quadratic equation format ax^2 + bx + c = y. There is a focus on determining the coefficients a, b, and c based on the given roots and point.
Some participants have offered insights into using the factor theorem to express the quadratic function in terms of its roots. Others are questioning how to apply the information about the point (0, 8) to find the coefficients. There is an ongoing exploration of different forms of the quadratic equation and their implications.
Participants are navigating the distinction between different representations of the quadratic function and the implications of using various coefficients. There is also mention of potential confusion regarding the notation used for coefficients in different contexts.
Eleeist
Find the quadratic function which has x-intercepts -2 and 2 and passes through the point (0,8).
I am struggling with solving this one. I tried to substitute values into ax^2+bx+c=y but there are too many unknowns.
Can anyone give some tips how to solve it?
Substituting values in [itex]y=ax^2+bx+c[/itex] is a good approach. Can you tell us what you get if you do this?
Well, I know c = 8, but I still don't know the values of a and b.
ax^2+bx+8=y.
-2 and 2 are x-intercepts, what does that mean?? What points lie on the parabola??
It means that they cross the x axis. And where they cross y=0... But then I get this:
a(2)^2+2b+8=0
I still have two unknowns.
Yes, so 2 is an x-intercept thus
4a+2b+8=0
Also -2 is an x-intercept, thus: ...You'll end up with a system of 2 equations and 2 unknowns.
Ok, got it:
-2x^2+8=y
Thanks.
You also might have noticed that, given the roots -2 and 2 your equation must have been ##y = c(x-2)(x+2) = c(x^2-4)## which would have had only one unknown.
And what if the point which the function crosses is not y-intercept, eg (4,18)?
Are you addressing that question to me? What difference does that make? Put in x = 4, y = 18 and solve for c.
But then I don't have b and a.
Eleeist said:
But then I don't have c.
Huh?? If you put x=4, y = 18 into y = c(x2-4) you get 18 = c(16-4).
Sorry, I meant b and a and was referring to the equation in form ax^2+bx+c=y. How would I go about using this form to solve the problem?
Also, could you please explain in more detail this:
y=c(x−2)(x+2)
I think I am seeing this form for the first time, but I might be wrong.
y=c(x−2)(x+2)
Presumably you know the factor theorem: If r is a root of a polynomial, then (x-r) is a factor. So your two given roots imply that (x-2) and (x+2) are factors. Two linear factors make a quadratic and the only question is a possible multiplier, or coefficient of x2. That is you you can deduce the form of the polynomial must be:
y=c(x−2)(x+2).
Then putting in your other point determines c. It is equivalent to how you solved the problem, but a little easier.
Yes, I know the factor theorem. But I cannot understand how you can deduce y=c(x-2)(x+2). Do you suggest that c is coefficient of x^2 (of course it is to)?
You are given that 2 and -2 are the x-intercepts. That means that
(x - 2) and (x - (-2)) = (x + 2)
are factors of this quadratic.
So y has to equal
y = a(x - 2)(x + 2)
(I don't like using c -- to be consistent with the OP I'll use a)
Plug in the point (0, 8) and you'll have a.
I understand that part. But how did the c get before brackets?
Say that 3 and 5 are the zeros of another quadratic. Then, without any further information, you could say that the quadratic is
y = (x - 3)(x - 5) = x2 - 8x + 15.
But that's not the only quadratic that would work. This one would also work:
y = 5x2 - 40x + 75
If you find the zeros of this quadratic, you will find that they will also be 3 and 5. This quadratic happens to be 5 times the first quadratic:
5x2 - 40x + 75 = 5(x2 - 8x + 15)
In general, given the zeros of a quadratic p and q (and nothing else), the quadratic would be
y = a(x - p)(x - q)
However, in the OP, a point is also given, which means that we need to find a specific value of a that would allow the quadratic to go through that point.P.S. You realize that the c in y = c(x - 2)(x + 2) is not the same as the c in y = ax2 + bx + c, do you?
No. I actually realized that just now :). I thought you meant "c" as y-intercept. But now that you explained that it is rather "a", then I understand the logic.
Thanks for detailed explanation.
Good job of catching that eumyang. I hadn't caught that his difficulty was with the fact I had used "c" instead of "a" in my explanation.
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 23 ·
