How to find which of three points are on a line?
  • Thread starter Thread starter rocapp
    Line Points
To determine which points lie on the line defined by the parametric equations, it is essential to find a common value of t for each point. Points P(1,2,0) and Q(-5,1,5) yield compatible equations resulting in the same t value, confirming they lie on the line. In contrast, point R(-4,2,5) produces incompatible equations, indicating no single t satisfies all three conditions. The analysis shows that the compatibility of all three components (i, j, k) is crucial for a point to be on the line. Thus, only points P and Q are valid, while R is not.
rocapp
Which of these three points falls on the line?
l: r(t)=(i+2j)+t(6i+j-5k)
P(1,2,0); Q(-5,1,5); R(-4,2,5)
I have the answer, but I don't understand why P and Q fall on the line but R does not. Is it because the i and j magnitudes are different for R?
P:
(1+6t) = 1
t=0
2=2+t
t=0
t=0
Q:
-5=1+6t
t=-1
1=2+t
t=-1
t=0
R:
-4=1+6t
t=-5/6
2=t+2
t=0
t=0
First, you are right that P and Q fall on the line and R does not. And as you see, R is not on the line because using those points you get 3 incompatible equations in t.
Whether a point falls on a line depends on all 3 magnitudes, i, j and k, and the trivial answer to your question is that most combinations will not work i.e. most 3 dimensional points are not on any given line.
However, working backwards from the equation we can get some insight. For example r(0) = i + 2j. So the point that fits there is P = (1,2,0). When you look at r(-1) = -5i + j - 5k, you see that Q = (-5,1,-5) is a point on the line.
But your incompatible equation for R tells you that there is no possible t for which r(t) = R. It's not really deeper than that.
Thanks! I think I understand, but what about the t=0 in R? Does this value not count since there is already an incompatible value in its components?
P:
(1+6t) = 1
t=0
2=2+t
t=0
t=0
Q:
-5=1+6t
t=-1
1=2+t
t=-1
t=0
R:
-4=1+6t
t=-5/6
2=t+2
t=0
t=0
The line has parametric equations x = 1 + 6t, y = 2 + t, z = -5t. A point (a,b,c) lies on the line if the equations a = 1+6t, b = 2+t, c = -5t are compatible; that is, we must get the same t from all three equations.
Thanks a bunch! That's what I needed.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
