How to get the lowest order ChPT amplitudes?
  • Context: Graduate
  • Thread starter Thread starter Thor Shen
    Amplitudes
The discussion revolves around the calculation of the lowest order amplitudes in Chiral Perturbation Theory (ChPT), focusing on the derivation of the relevant Lagrangian and the resulting amplitudes for pion-pion scattering processes. Participants explore the mathematical formulation and the implications of symmetry in the context of particle interactions.
  • One participant presents the lowest order Lagrangian for ChPT and derives the amplitudes for the reaction involving pions, expressing them in terms of Mandelstam variables.
  • Another participant discusses the symmetry involved in the contraction of operators, suggesting that each operator can connect to incoming or outgoing states, leading to a factor of four for the ##m_{\pi}^2## term.
  • A participant expresses confusion regarding the application of operators on states, questioning the implications of crossing symmetry and the resulting contractions.
  • Further clarification is provided regarding the use of creation and annihilation operators, emphasizing the need to understand the algebraic manipulations involved in the LSZ reduction process.
  • Another participant introduces the concept of the "hat" operators representing plane wave solutions and discusses their derivatives in relation to momentum.
Participants exhibit a mix of agreement on the mathematical framework but express differing interpretations and confusions regarding specific operator applications and the implications of symmetry in the calculations. The discussion remains unresolved on certain points, particularly regarding the handling of operators and the resulting amplitudes.
Limitations include potential misunderstandings of operator algebra, the dependence on specific definitions of operators, and unresolved steps in the mathematical derivation of amplitudes.
Thor Shen
Note from mfb: I fixed the LaTeX formulas[/size]
http://image.keyan.cc/data/bcs/2015/0428/w84h1446064_1430226899_628.jpg
I met some trouble by using latex on this version, so I try to add the image from the pdf,
the Latex code is as follow if any help.
The lowest order lagrangian for ChPT is
[itex]\mathcal{L}^{(2)}=\frac{f^2}{12}\langle(\partial\Phi \Phi-\Phi\partial\Phi)^2+M\Phi^4\rangle[/itex]
where the isospin limit is assumed and the $\Phi$ is made of the pseudo Goldstone boson fields,
$$\begin{pmatrix}
\frac{\pi^0}{\sqrt{2}}+\frac{\eta}{\sqrt{6}} & \pi^+ & K^+\\
\pi^-& \frac{-\pi^0}{\sqrt{2}}+\frac{\eta}{\sqrt{6}} & K^0\\
K^-& \overline{K}^0&\frac{-2\eta}{\sqrt{6}}\\
\end{pmatrix}$$Let us consider the physical reaction $$I=0~\pi^+(\vec{k})\pi^-(\vec{p})\leftrightarrow\pi^+(\vec{k'})\pi^-(\vec{p'})$$,where the k,p,k' and p' are the momentums of the pion, respectively. The relevant lagrangian can be derived from the above formula,
$$\begin{eqnarray}\nonumber
\mathcal{L}_{\pi\pi\pi\pi}&=&2\partial\pi^+\partial\pi^+\pi^-\pi^- -2\partial\pi^+\partial\pi^-\pi^+\pi^--2\partial\pi^-\partial\pi^+\pi^+\pi^- \\ \nonumber
&&+2\partial\pi^-\partial\pi^-\pi^+\pi^+ +2m^2_{\pi}\pi^+\pi^+\pi^-\pi^-
\end{eqnarray}$$
and the amplitudes of this reaction,
V(s,t,u)&=&\langle\pi^+\pi^-|H|\pi^+\pi^-\rangle \\ \nonumber
&=&-\langle\pi^+\pi^-|\mathcal{L}|\pi^+\pi^-\rangle \\
=-\frac{1}{6f^2}&\{&\langle\pi^+(k')\pi^-(p')|\partial\pi^+\partial\pi^+\pi^-\pi^-|\pi^+(k)\pi^-(p)\rangle\\
&-&\langle\pi^+(k')\pi^-(p')|\partial\pi^+\partial\pi^-\pi^+\pi^-|\pi^+(k)\pi^-(p)\rangle\\
&-&\langle\pi^+(k')\pi^-(p')|\partial\pi^-\partial\pi^+\pi^+\pi^-|\pi^+(k)\pi^-(p)\rangle\\
&+&\langle\pi^+(k')\pi^-(p')|\partial\pi^-\partial\pi^-\pi^+\pi^+|\pi^+(k)\pi^-(p)\rangle\\
&+&\langle\pi^+(k')\pi^-(p')|m^2_{\pi}\pi^+\pi^+\pi^-\pi^-|\pi^+(k)\pi^-(p)\rangle\}.
\end{eqnarray}$$
Finally, the result can be expressed as $$-\frac{1}{3f^2}(s+t-2u+2m^2_{\pi})$$ with the Mandelstam variables $$s=(k+p)^2$,$t=(k-k')^2$$ and $$u=(k-p')^2$$, that is $$-\frac{1}{6f^2}(2(k-k')^2-2(k-p')^2-2(k-p')^2+2(k+p)^2+4m^2_{\pi})$$. Then how to get the answers by the five amplitudes, respectively?
Do you understand how to get the last one, the ##m_{\pi}^2## term?
there's symmetry involved. Each operator ##\pi^{+}## can be contracted to either an incoming ##\pi^{+}## or an outgoing ##\pi^{+}##. So you have 2 connections. Same with the ##\pi^{-}##, so there's a symmetry of ##2*2= 4##. Thats why there's ##4 m_{\pi}^2##. Draw a physical line from each type of operator to their in.out states and make sure all operators are connected.
The pions are spin-0, so when they operate on a in/out state, it just creates or annhiliates that state. it contracts and you get "1". They also commute with each other at this level, so theyre free to move around to order them properly.
For the derivatives, these give you a factor of the momentum times the pion operator again. The sign of the momentum depends on how you've defined the incoming/outgoing.
You can get this by taking the derivative of the free-pion wavefunction, which is just an exponential.
Well,thank you for your apply, but I still have some confusions.
For example,the operator π+and π- act on the state |π+π->.
π+π-+π->=|π+π->? (1)
π+π-|0 0>=|π+π->? (2)
+π-+π-=<π+π-|? (3)
<0 0|π+π-=<π-π+|? (4)
if we consider the crossing symmetry, we can rewritten the <π1+π2-+π-π+π-|π3+π4-> as <0|π+π-π+π-1-π2+π3+π4->. Then the operators act on the vacuum state as <π1-π2+π3+π4-1-π2+π3+π4->=1.
The four is from the commutative operators because the 4 permutation which is π1+π2+π3-π4-,π1+π2+π4-π3-,π2+π1+π3-π4-,and π2+π1+π4-π3-?
ok, maybe the notation is confusing. Think about it this way, in creation/annihilation operators :
\hat{\pi}^{+} | \pi^{+} \rangle \\
\hat{\pi}^{+} \pi^{\dagger+}| 0 \rangle \\
(1) | 0 \rangle
$$Where ##\hat{\pi}^{+} ## is the full operator and contains both ##\pi^{+} ## and ##\pi^{\dagger+}##
Where the last line is from the contraction between the two operators.
We're basically doing LSZ reduction, but at a much more algebraic way, so we have to understand all of the shortcuts we're using.
I wish i could draw a connecting line for them like in Peskin&Sch.
You should write out all the creation/annhilation operators so you're left with ##<0|0>## which is 1.
When you have 2 :
\langle \pi^{+} |\hat{\pi}^{+} \hat{\pi}^{+} | \pi^{+} \rangle \\
\langle \pi^{+} | \hat{\pi}^{+} \hat{\pi}^{+} \pi^{\dagger+}| 0 \rangle \\
\langle 0 |\pi^{+} \hat{\pi}^{+} \hat{\pi}^{+} \pi^{\dagger+}| 0 \rangle \\
then you do the 2 possible contractions between the creation/annhilation operators and the operators with the hat, that contain a sum of both.
the operator with hat likes the number operator as $$\hat{\pi}^+=\pi^{\dagger+}\pi^+$$ ,as well as $$\hat{\pi}^-=\pi^{\dagger -}\pi^-$$. And the operators without hat are satisfied with the boson commutation relation?
Technically its more that the hat ones are the plane wave solutions in the LSZ, right?
##\hat{\pi} = (...)(e^{i k \cdot x} \pi^{\dagger} + e^{-i k\cdot x} \pi )##
this also tells you what you get when you take derivatives:
##\partial_{\mu} \hat{\pi} = (...)((i k_{\mu} )e^{i k \cdot x} \pi^{\dagger} + (-i k_{\mu} )e^{-i k\cdot x} \pi )##
but $$k$$ depends on which field it contracted with.
