How to Plot a Polygon on X-Y Graph Knowing the Radius
4 replies · 9K views
quddusaliquddus
I want to plot a Regular Polygon of many sides on a X-Y graph where I know the number of sides and the radius.
I would like a method to calculate the position of the corners of this shape without using compass/ruler.
If there was an algorithm that goes all the way around the shape then that'd be better.
x^2 + y^2 = r^2
http://en.wikipedia.org/wiki/Polygon"
Im afraid I am completely stuck on this. I keep going from calculating all the angles and length of sides of each triangle segment of the polygon to a x-y graph where I am trying to calculate the x-y coordinates of the corners.
Hi. At the link I provided there is a formula:
(x,y) = 2R(cos(t), sin(t) )*sin ( t + arcsin ( a / 2R ) )
I just wanted to get ot confrmed that it is correct. It doesn't look it.
That formula will give a "smooth" curve, not a "broken line" as you need for a polygon.
If you want to construct a regular polygon with n sides, radius r, center at [itex](x_0,y_0)[/itex], the line from the center to one vertex making angle [itex]\theta[/itex] with the x-axis, the coordinates of the vertices are given by
[tex]x= x_0+ r cos(\left(\frac{2\pi}{n}\right)i+ \theta)[/tex]
[tex]y= y_0+ r sin(\left(\frac{2\pi}{n}\right)i+ \theta)[/tex]
Where i runs from 0 to n-1.
Thanks. Thats exactly what I needed.
