How to solve quadratic vector equation?
  • Thread starter Thread starter Jeno
    Quadratic Vector
The discussion centers on solving the quadratic vector equation (a)² + a · b - c = 0, where a and b are vectors and c is a scalar. Participants clarify that (a)² should be interpreted as a · a, leading to the equation |a|² + |a| |b|cos(θ) - c = 0, which is quadratic in |a|. The conversation highlights the importance of understanding vector magnitudes and directions, as well as the implications of having no real solutions in certain scenarios, similar to traditional quadratic equations.
  • Understanding of vector operations, specifically dot product
  • Familiarity with quadratic equations and their properties
  • Knowledge of vector magnitudes and angles between vectors
  • Basic algebraic manipulation skills
  • Study vector algebra, focusing on dot products and their geometric interpretations
  • Learn about quadratic equations and conditions for real solutions
  • Explore vector equations in three-dimensional space
  • Investigate the implications of vector direction on solutions to equations
Students and professionals in mathematics, physics, and engineering who are dealing with vector equations and their applications in various fields.
Jeno
(a)2 + a · b - c = 0
a and b are vectors which (in general) with different directions while c is a scalar. How to solve for a?​
(a + (1/2)b)2 - (1/4)b2 - c = 0
(a + (1/2)b)2 = (1/4)b2 + c​
In this case, if i carry the square from left hand side to right hand side, it appears that the left hand side turns into a vector while the right hand side remains as a scalar. I wonder why this happens and what would be the proper way to solve this equation.​
What does a2 mean if a is a vector?
Hi, I think a2 should be a scalar with the magnitude of the square of the length of the vector a. Is there any problem with it? Do you know how to solve this equation?
Thank you.
Thank you.
I'm pretty certain that what you have as a2 should be written as a · a. Assuming your equation is a · a + a · b - c = 0, you can use one of the definitions of the dot product to rewrite this equation as
|a|2 + |a| |b|cos(theta) - c = 0, where theta is the angle between a and b. This equation is quadratic in |a|.
Given that a2 means a\cdota the equation doesn't have a unique solution and may have none. If you let:
\vec a = \langle x,y,z\rangle,\, \vec b = \langle u,v,w\rangle
the equation becomes:
x^2+y^2+z^2+xu+yv+zw-c = 0
which, depending on the various constants, might be a sphere or nothing.
Ya, i think a2 = a · a . Is there any other definition for a2?
So, if i don't know the direction of a, then i can't solve for a is it?
I think, in my situation, i can guess the direction for a. Let's say if i know that the direction of a is r (a vector with magnitude of r, such that r/r is a unit vector), so how can i solve for the equation without expressing it in the angle between them (theta), and just the vectors and scalar of b, c and r?
a=-(r/2r2)( +- (4r2c + (b · r)2 )1/2 + r · u )
This is the answer given in the book. It seems like after applying the formula to find the root of quadratic equation, then he multiply it with r2/r2. But it didn't sound quite correct to me if you consider the vector BAC CAB rule. The cross product term didn't appear in this equation, and in my situation, b can be in any direction, which doesn't restricted to be parallel to a.
Sorry, what do you mean by "nothing" here?
Thank you.
Thank you.
I mean there is no solution. For example, with the right choice for u,v,w, and c, the equation might end up something like
(x-1)^2 + (y+2)^2+(z-3)^2 = -10
having no real solutions.
So is it similar to the normal quadratic equation where b2 - 4ac < 0 gives no real solution? ok, then i understand.
But i still don't understand how the book get the the expression above. I think the expression above should be valid, since it is written on the book, but i just don't know how to get that through a proper way.
Can anybody help? Thank you.
What "expression above"? You showed no expression that you said came from the book.
This is the expression i meant. Thank you.
How is this equation related to the equation in post #1? The original equation involved vectors a and b, and a constant c. The equation you just showed has r and u, which aren't in the original equation.
Also, your last equation is very difficult to read, as it has what appear to be exponents that aren't shown as such. For example what you have written as 4r2c could be (4r)(2c) or might be 4r2c. And I'm guessing that (b · r)2 )1/2 is (b · r)2 )1/2.
It's pretty easy to write exponents using the advanced menu. Click the Go advanced button, and use the X2 button.
Sorry, i have typed it wrong. The expression should be as follow:
a=-(r/2r2)( +- (4r2c + (b · r)2 )1/2 + r · b )
where r is a vector with direction of a and length of r.
Thank you.
