How to Solve the Complex Polynomial Product Equation?
  • Thread starter Thread starter anandzoom
8 replies · 2K views
anandzoom
(1+x+x2+x3+x4+x5+x6+x7+x8)(1+x2+x4+x6+x8)(1+x3+x6)(1+x4+x8)(1+x5)(1+x6)(1+x7)(1+x8) = 1+x+2x2+3x3+5x4+7x5+11x6+15x7+22x8+...+x56
Please explain me the step-wise procedure to arrive at the solution.
Are those supposed to be exponents on the variable, x ?
Use that X2 feature in the green bar above the edit/composition box.
This gives something like: (1+x+x2+x3+x4+x5+x6+x7+x8)(1+x2+x4+x6+x8) ...
Furthermore:
You should use the supplied template when starting a thread, as well as showing an attempt at solving/understanding the problem you're presenting.
The only way I see to solve it is to multiply out the left side. Then move everything to one side and hope that many of the high-exponent terms disappear. Maybe there will only be a low order polynomial left. Look for the zeros of the polynomial.
Assuming those are exponents, that is a polynomial equation of degree 56. There exist "formulas" for polynomial equations of degree 4 or less but there is NO 'step by step" way of solving a general polynomial of degree five or higher and certainly not 56!
I noticed that the x56 term cancels out. I assume the question has been rigged so that many terms cancel out.
Everything is in '+' ... terms can cancel out only if there is some '-' if I'm right
Notice that both sides have +x56. (To see that on the left, scan through all that multiplication and notice that all the highest power terms multiply out to +x56). ) You can subtract x56 from both sides and the rest stays equal. My guess is that a lot of the high-power terms cancel out just like x56.
My guess is that the right hand side is merely the expansion of the left hand side, so they ALL cancel.
OP still has not complied with PF rules.
