How to Transfer Intermittent Rotary Motion to a Continuously Running Flywheel?
  • Thread starter Thread starter zydubion1
    Motion Rotary
The discussion revolves around the challenge of transferring intermittent rotary motion from a driver to a continuously running flywheel. Participants explore various mechanical solutions to achieve this transfer while addressing concerns about engagement and potential issues during operation.
  • One participant describes the need for a mechanism that allows a driver to push a flywheel intermittently, with the driver disengaging after each push.
  • Another suggests using a clutch combined with a fluid coupling to prevent jerking and losses during engagement.
  • A proposal is made for using spur gear teeth on the flywheel and a driver with limited teeth to allow for engagement and disengagement without continuous contact.
  • Concerns are raised about the potential for gear teeth to mesh improperly or crash, with a suggestion that a synchro system could mitigate this risk.
  • One participant advocates for an overrunning clutch as a suitable solution for the described problem.
  • A standard automobile starter mechanism is mentioned as a possible reference point, highlighting its automatic disengagement when the flywheel exceeds the pinion gear's speed.
Participants express various viewpoints on the mechanisms that could be employed, with no consensus reached on a single solution. Multiple competing ideas are presented, indicating an ongoing exploration of the topic.
Participants discuss various mechanical configurations and their implications, but limitations regarding specific designs, operational conditions, and the feasibility of proposed solutions remain unresolved.
zydubion1
I have intermittent rotary motion that I want to send to a continually running flywheel. The flywheel in mounted to one shaft, the intermittent rotary motion comes from a wheel or gear (driver) that is mounted to another shaft. Shafts are parallel. The flywheel is continually running but not rotating at a constant speed. Regardless of the flywheel speed, I want to be able to occasionally and at random give the flywheel a push via the driver when the driver gets a burst of random energy. When the driver does get a burst of energy, it will have this energy for only one revolution and it will then stop and wait for the next burst of energy. The driver wheel or gear can stop in a waiting location that is disengaged from the flywheel. Can someone direct me to the possible mechanisms that can perform this task?
Perhaps you can try some sort of clutch+fluid coupling as an automatic transmission. It seems like any direct mechanical coulpling wouldn't work as it would necessitate the two wheels to be moving at exactly the same speed when they engage otherwise there would be lots of jerking and losses.
What if the OD of the flywheel had spur gear teeth, and the driver also has mating gear teeth but only about 3 or 4 teeth, the rest of the driver OD without teeth. The driver would stop immediately after delivering a push to the flywheel and the teeth of the driver would be just past and disengaged from the flywheel teeth. There, the driver would lay in waiting for the next burst of energy. Then it would rotate one full revolution, engage with the flywheel, give the push, and again stop just outside the reach of the gear teeth. Thus there is no tooth engagement whilst the flywheel is able to continue rotating. Does any such device exist? Would the gear teeth mesh or sometimes crash?
I suppose that a synchro system, as is used in a manual car transmission, might avoid crashes. This was actually the first thought that I had when reading the OP. An overrunning clutch (like an automotive Bendix) might be easier, though.
This problem description really calls for an over running clutch in one form or another. Look at the possibility of a a sprag clutch for this application.
The standard automobile starter with the starter (pinion) gear on a helical spline driving a flywheel might be a good statring point. You might have to drive a parallel geared up axle with the helical spline on it to get the speed necessary to engage the flywheel with the pinion gear. The nice thing about the pinion gear on the helical spline is that it releases automatically when the flywheel is going faster than the pinion gear.
12K
9K
