High School How to understand 'covariance' and 'contravariance'
  • Thread starter Thread starter chaksome
    Covariance
This discussion focuses on the concepts of covariance and contravariance in the context of special relativity and general manifolds. Covariant components transform in the same manner as the tangent vector basis, while contravariant components transform oppositely. The discussion illustrates these concepts using examples, such as measuring the length of a running track, emphasizing the invariance of the product of covariant and contravariant quantities. The importance of the metric in understanding these transformations is also highlighted, showcasing the complexity of these concepts in higher-dimensional spaces.
  • Understanding of special relativity and its mathematical framework
  • Familiarity with vector spaces and basis transformations
  • Knowledge of differential geometry and manifolds
  • Basic grasp of metrics and their role in geometry
  • Study the mathematical definitions of covariant and contravariant vectors in differential geometry
  • Explore the role of the metric tensor in transforming between covariant and contravariant components
  • Learn about tangent and dual bases in the context of vector spaces
  • Investigate practical applications of covariance and contravariance in physics, particularly in general relativity
Physicists, mathematicians, and students of theoretical physics who seek to deepen their understanding of vector transformations in relativity and geometry.
chaksome
TL;DR
covariance covariance
When I come into contact with these two concept in the book of Landau, I gradually know how to use ##A^i or A_i## to simplify the calculation in special relativity.
But I found it hard to give an explicit explanation for them(including gauge matrix) in the aspect of physics.
Could you please give me some illumination? Thanks~
Covariant components transform in the same way as the tangent vector basis, hence "co-". Contravariant components transform in the "opposite" way as the tangent vector basis, hence "contra-".
A vector is a geometical object and does not depend on the basis you use to describe it. Hence, the components need to transform opposite to how the basis they are used with transforms. Therefore, if you use the tangent basis ##E_\mu##, you need to use the contravariant components such that the vector ##V = V^\mu E_\mu## is invariant. Conversely, if you use the dual basis ##E^\mu##, you need to use the covariant components ##V = V_\mu E^\mu## to have a coordinate independent object.
Things become slightly more complicated in a general manifold where there is no direct link between tangent and dual vectors, but generally tangent vectors (with coordinate bases) then have contravariant components and dual vector covariant components.
Likes Minnesota Joe, dextercioby, chaksome and 1 other person
An example I found useful is the length of a running track. I can measure it by taking a standard ruler and laying it end-to-end N times. The track length is therefore N units.
But now I redefine my standard unit, and the new standard length is exactly twice my old unit. So I need new standard rulers, and the length of the track becomes N/2 new units.
So, under the length redefinition by a factor of two, ruler lengths covary (they increase by a factor of two) while the counts of rulers needed contravary (they decrease by a factor of two). The physically meaningful thing, the product of standard ruler length and the number of rulers I needed to use (the product of a contravariant and a covariant quantity), is invariant.
Orodruin's explanation is better - this is just an example of the kind of thing he's talking about.
  • Wow
Likes Minnesota Joe, chaksome and FactChecker
Contravariant unitvector ##\vec{x^i}## is pointed to direction where i'th contravariant coordinate changes most per distance.
Covariant unitvector ##\vec{x_i}## is pointed to direction where only i'th contravariant coordinate changes(other contravariant coordinates remain same).
I am not sure it is better, it is just a different illustration that is restricted to the one-dimensional case where there is only one direction so you only have to worry about scaling of the base vector (and not scalings and rotations as in the general case).
This is a bit misleading since coordinates in general are neither co- nor contravariant, they are just functions on the base space.
The more accurate description is to say that the tangent vector basis ##E_\mu = \partial_\mu## (the basis whose transformations define what covariant means) point in the direction of the respective coordinate lines and that the dual basis ##E^\mu = dx^\mu## consists of the one-forms that map the corresponding tangent basis vectors to one and the others to zero. The interpretation in terms of "change per distance" is contingent on the existence of a metric.
You've also covered (or at least introduced) the role of the metric in all of this, where I've blithely assumed I have one.
Maybe I am being a bit harsh to my answer. The formal mathematical machinery is extremely powerful and necessary, but it was an example of the type I gave (in @bcrowell's book, I think) that started to give me a feel for what co- and contra-variant quantities could be, physically.
  • · Replies 151 ·
25K
