I cant seem to get this angular velocity problem right
The discussion revolves around calculating the angular acceleration of a large pottery wheel driven by a smaller rubber wheel, with the small wheel accelerating at 7.10 rad/s². The calculated angular acceleration for the pottery wheel is 0.6 rad/s². The second part of the problem involves determining the time for the pottery wheel to reach 72 RPM, which translates to 7.54 rad/s. The user initially calculated the time as approximately 12.57 seconds but faced issues with accuracy and significant figures. After revisiting the calculations, the user confirmed the solution was correct.
xxxixpats
Code:
A small rubber wheel (radius of 2.60 cm) is used to drive a large pottery wheel (radius of 33.00 cm), and they are mounted so that their circular edges touch. If the small wheel accelerates at the rate of 7.10 rad/s2, and there is no slipping, what is the angular acceleration of the large pottery wheel?
I answer this and it came out to .6 rad/s^2
Then the second part of the equation says
Code:
In the above problem, what is the time taken for the pottery wheel to reach the required speed of 72 rpm?
I simply used the equation
w=w0+at
- W0 would cancle leaving the formula
W=at
72RPM = 7.54 rad/s
7.54/.6 = 12.5667 s
This seems right but it keeps telling me I am wrong
Your angular acceleration is a little off. How many significant figures do you actually need?
not really sure all it posted was 1, I redid the problem and got it write
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
