I get this error when I try to run the code MCNPX
5 replies · 4K views · last reply
emilmammadzada
TL;DR
I get this error"bad trouble in imcn in routine pass1 unexpected eof in file depletion.inp" when I try to run the code MCNPX
my input file
Code:
c Depletion pincell input file for MCNPX
c Define cells
c   Cell 1: Fuel
1 0 -1.0 -4 -5 -6
c   Cell 2: Cladding
2 0 -2.0 4 -7
c   Cell 3: Moderator
3 0 -3.0 5 6 7
c   Cell 4: Outside
4 0 4 -8
c Define surfaces
c   Surface 4: Inner radius of fuel
4 rpp -0.3937 0.0 0.0 0.3937 10.16 10.16
c   Surface 5: Outer radius of fuel
5 rpp -0.5080 0.0 0.0 0.5080 10.16 10.16
c   Surface 6: Top of fuel
6 pz 10.16
c   Surface 7: Bottom of fuel
7 pz 0.0
c   Surface 8: Outer boundary
8 sphere 0.0 0.0 0.0 15.24
c Define materials
M1 8016.70c -1.0
     8017.70c -0.0072
     92235.70c -0.0001
     92238.70c -0.9927
c Define depletion parameters
DEPL IBURN 1 1 1E-6
DEPL NLIB 9 9
DEPL RDTOL 1E-6
DEPL MAXORD 10
DEPL TDEL 1E-6
DEPL TOTTIME 365.0
c Define initial conditions
IC1 1 1.0 1
c Define run parameters
MODE N
NPS 100000
c Define tallies
F1:n 1 1 0 7 -4 -5 -6
F2:n 2 1 0 7 4
I'm not sure if this is the problem or not, but the first thing I noticed is that you need single blank lines after the cell card definitions and after the surface card definitions to define the different "input blocks".
Insert a blank line after line 10, and after line 21 (which will be 22 if you submit the first blank line)
The definition of sphere has failed, how can I fix it?
Code:
 *                   MCNPX                                   *
 * Copyright 2007. Los Alamos National Security, LLC.        *
 * All rights reserved.                                      *
 * This material was produced under U.S. Government contract *
 * DE-AC52-06NA25396 for Los Alamos National Laboratory,     *
 * which is operated by Los Alamos National Security, LLC    *
 * for the U.S. Department of Energy. The Government is      *
 * granted for itself and others acting on its behalf a      *
 * paid-up, nonexclusive, irrevocable worldwide license in   *
 * this material to reproduce, prepare derivative works, and *
 * works, and perform publicly and display publicly.         *
 * Beginning five (5) years after June 1, 2006, subject to   *
 * additional five-year worldwide renewals, the Government   *
 * is granted for itself and others acting on its behalf     *
 * a paid-up, nonexclusive, irrevocable worldwide license    *
 * in this material to reproduce, prepare derivative works,  *
 * distribute copies to the public, perform publicly and     *
 * display publicly, and to permit others to do so.          *
 * NEITHER THE UNITED STATES NOR THE UNITED STATES           *
 * DEPARTMENT OF ENERGY, NOR LOS ALAMOS NATIONAL SECURITY,   *
 * LLC, NOR ANY OF THEIR EMPLOYEES, MAKES ANY WARRANTY,      *
 * EXPRESS OR IMPLIED, OR ASSUMES ANY LEGAL LIABILITY OR     *
 * RESPONSIBILITY FOR THE ACCURACY, COMPLETENESS, OR         *
 * USEFULNESS OF ANY INFORMATION, APPARATUS, PRODUCT, OR     *
 * PROCESS DISCLOSED, OR REPRESENTS THAT ITS USE WOULD NOT   *
 * INFRINGE PRIVATELY OWNED RIGHTS.                          *
 warning.  rpp is infinite in one dimension.
 fatal error.  the surface type is not recognized:  sphere
 m1 8016.70c -1.0
 warning.  material   1 is not used in the problem.
 depl IBURN 1 1 1E-6
 fatal error.  depl  is not a legal data symbol.
 depl NLIB 9 9
 depl RDTOL 1E-6
 depl MAXORD 10
 depl TDEL 1E-6
 depl TOTTIME 365.0
 ic1 1 1.0 1
 fatal error.  ic    is not a legal data symbol.
 warning.  total nu is now the default for fixed-source problems.
 f2:n 2 1 0 7 4
 fatal error.  surface     -1 not found for cell     1 card.
 bad trouble in imcn     in routine mbody
 surface error
 warning.  plot plane coincident with surface      4
There are many problems with this input. Have you tried to look in the manual and example problems? I would start with one of the example problems distributed with the code and try to understand how it works.
The "fatal error" message tells you exactly what the problem is. The keyword "sphere" is not a recognized surface type. If you look in the manual, you should be able to find a table that lists the available surface types.
Once you fix this error, you will get several errors about the materials. None of your cell cards include a valid material number and the densities are not correct. Once you fix this, you will find that you are missing material definitions for the cladding and moderator.
Next, you will find that a fixed source problem is probably not what you want to run. Look at the examples on how to run a criticality problem using the "kcode" option.
I suggest taking out all of the "DEPL" and "IC1" cards and just try to get a simple problem working before trying to deplete. Look at the sample problems to understand how to set up the geometry and materials.
  • Love
I just looked at your previous posts, and it looks like several people have tried to help you set up your MCNP cases, but you don't appear to understand the very basics of how to set up the code.
Instead of randomly "trying things", I suggest sitting down with an example input and going through the manual and try to understand what each input line does. There are many samples distributed with the code, and you can find more on the web.
It will take some time, but it is necessary if you are going to understand how to set up a problem and interpret the results.
I'm currently working on openmc and serpent. It's been a while since I looked at mcnpx. That's why I don't remember a lot of things. I think this code about mcnpx may have mixed this input file with the input files of other codes. I'll look into this again.))
