I need the definition of a few basic physics terms. Can anyone help?
This discussion focuses on the definitions of fundamental physics terms: object, particle, body, extended body, and rigid body. An object is defined as anything that has shape or can move. A particle is typically a point mass, while a body refers to a solid mass of unspecified size and shape. An extended body distinguishes itself from a point object by having a physical extent, and a rigid body is characterized as an object that cannot be deformed, maintaining fixed distances between its points. These definitions are essential for understanding basic physics concepts in a college-level physics I course.
  • Basic understanding of physics terminology
  • Familiarity with concepts of mass and shape
  • Knowledge of point mass versus extended object distinctions
  • Introduction to mechanics and statics principles
  • Research the concept of point mass in physics
  • Study the differences between rigid bodies and deformable bodies
  • Explore the implications of extended bodies in mechanics
  • Learn about particle physics and fundamental particles
Students enrolled in introductory physics courses, educators teaching basic physics concepts, and anyone interested in foundational definitions in mechanics and physics terminology.
syohannan
So, I know this stuff is probably very elementary for most of the people on this site, but I have never had physics before, and I just started physics I at college. The professor has asked us to learn a few basic physics terms and I am having a hard time finding clear definitions for some of them.
These are what I need defined:
object
particle
body
extended body
rigid body
Thanks!
welcome to pf!
hi syohannan! welcome to pf! :wink:
syohannan said:
object
particle
body
extended body
rigid body
have you tried wikipedia?
anyway, tell us what you think each one means :smile:
Yes, I have looked at several website as well as Wikipedia, and I am having a hard time finding clearly defined definitions for some of these.
I have found some of them, but I am still not confident that they are they best definitions, since I have seen several different ones for a few of these. Here is what I have found.
object = anything that has shape, but my teacher said anything that can move? This is why I am unsure.
particle = an inextricable piece of mass (this one I am OK with, unless you have something better. This is why I asked)
body = a mass of unspecified size and shape (but i have seen other sites that say, a body and an object are the same thing)
extended body (this one specifically I can not find a definition for at all)
rigid body = object with mass that has a very specific size and shape (this is my teacher's definition, but I have seen others that vary)
Can anyone please give me some clearly defined definitions for these, thanks
The concept of a rigid body is an interesting one for a beginner in that it can swiftly lead you to realize that it is an assumption that does not hold in the real world.
Rigid body = an object that does not bend at all e.g. a rigid bar supported at one end has no deflection in the Earth's gravitational field.
When I taught mechanics years ago we started with Statics i.e. the behaviour of material bodies with no motion. After some time on the subject, with the students confident of their prowess I would set the following three problems for homework then discussion:
A) a rigid bar, length x, mass m supported at it's mid point - what is the reaction at the support.
B) similar bar, supported at two points - what are the reactions at the supports (at various times I would specify different positions for the supports)
C) similar bar, supported at three pints - what are the reactions.
A & B they should solve easily, C gives a good discussion of what assumptions we make in trying to solve problems in the real world AND WHEN THOSE ASSUMPTIONS CEASE TO HOLD.
A particle need not have mass. Photons are particles, and they are massless. With that in mind, can you take another stab at it?
In my case it's usually about the three pint point.:biggrin:
Sorry I could not resist.
Partly right, partly wrong. Object in physics means pretty much the same as what it means in daily life. body normally means a solid (not liquid or gas), extended body or extended object - this is used to distinguish from 'point' object which are objects whose entire mass and extent is concentrated in one point( which occupy just one point literally) and anything which is not a point object is an extended object. rigid body - cannot be deformed - the distance between any two points on a rigid body cannot change. particle normally means a point mass, i.e. an object whose entire mass and extent is concentrated at one point. (in particle physics it has a slightly different meaning, there it means fundamental particle)
I like the following description of a classical point particle: It's an object whose motion can be described by a single curve in spacetime.
  • · Replies 190 ·
16K
  • · Replies 102 ·
