I would love some help on this problem
  • Thread starter Thread starter brendonnn
    Love
The discussion revolves around a physics problem involving the motion of an object thrown into the air and its subsequent fall back to the ground, specifically focusing on determining its acceleration and velocity upon impact. The context includes kinematics and the effects of gravity, with a total air time of 5 seconds and neglecting air resistance.
  • Participants discuss kinematic equations and the implications of initial and final velocities. There are attempts to clarify the relationship between time, displacement, and acceleration. Some participants question the assumptions made regarding initial velocity and the total time in the air.
The discussion is active, with participants providing guidance and prompting the original poster to engage with the problem. There are various interpretations of the calculations, and while some participants express confidence in their reasoning, others challenge assumptions and seek clarification.
Participants note discrepancies in the calculations, such as the total displacement being zero and the correct interpretation of time in the air. There is also mention of a typo regarding the time variable, which influences the discussion.
brendonnn
Okay, so! My physics is lacking, but my life sciences are excellent, but that won't save me.
How do I determine object's acceleration and velocity when it strikes the ground given:
An object is thrown up into the air and then falls back to earth, remains in the air for 5 seconds before striking the ground; neglect air resistance.
thanks in advance
Look up some equations about kinematics of falling objects. It's really a very popular topic. Let us know what you think and then we can get back to you. It's really not hard. But you have to start. Even a well-reasoned guess would help.
You know how to do it, but you just want me to try?
Well this is what I thought but I am unsure if it is right.
its original and final velocity will be 0 and that it takes 2.5 seconds to reach its maximum height and 2.5 more seconds to hit the ground. I think
Does this make sense at all?
displacement = initial velocity(change in time) + 1/2(acceleration)(change in time)^2
so
x = 0(10) + 1/2(9.81)(10)^2 ?
I know how to do it, and, yes, I want you to try. Good try. The total displacement is zero, since it came back to the ground. This means the initial velocity can't be zero. I would change 9.81 to -9.81 since the acceleration is downwards, and I would also ask why you are putting total time to be 10 since it was only in the air for 5s?
I thought about that as soon as I posted, well about the displacement being zero, and the 10 was a typo.
Then you have it solved, right?
is this right?
displacement = (initial velocity)(change in time) + 1/2(acceleration)(change in time)^2
0 = x(5) + 1/2(-9.81)(5)^2
approximately 24.5 m/s
Of course it's right. I told you you just had to try.
it traveled approximately 30.66 meters into the air and its final velocity before striking the ground was 17.34
There's symmetry in this example. The magnitude of the initial and final velocities should be the same.
Uh. No. What makes you think that. The initial velocity was 24.5m/sec. Shouldn't it strike the ground at the same velocity? The height is ok, though.
Okay, and thanks for the help. Physics is not my forte.
I could be. You aren't that bad at it. Life sciences isn't easy either.
I have a question that could make me seem potentially stupid.
Is it feasible to utilize electric currents to split ocean water into hydrogen and oxygen for the desalinization of ocean water and providing oxygen for submarines
Depends on what you mean by "feasible". You could do either one. Is it economical is another question. Depends on where the current comes from and what it costs and how much you want the product, etc.
Thanks for the answer and the push for me to do well on the problem.
  • · Replies 47 ·
  • · Replies 76 ·
10K
