Ideal material for Golf application
2 replies · 4K views · last reply
IbertIzzet
I'm currently in the process of designing a golf application. Because of what it is, it needs the following properties:Corrosion resistance, UV resistance, lightweight, and heat resistance although this is not essential as I could use a heat shield, I believe mica would be ideal for this.
So if anyone could suggest a metal or plastic with these proerties it would be very helpful.
Thanks
If you could be specific about the type of application, you'd be FAR more likely to get some help. You've left it very open-ended.
Even though em not 100% what type of application u are trying to develop but for heat release I can give u suggestion to use Au. I mean Pure Aluminum. It is used in Computers with a cooler fan and so it is the best materiel for releasing heat from ur device. Another important benefit is this metal is cheap and light weight. So its excellent for personal research and portable devices.
Hope this helps.
Thanks
Gorge.
Golf Lessons Livemore
