Identifying Substance Z Using Titration Method: Results and Analysis"
  • Thread starter Thread starter paulhunn
2 replies · 3K views · last reply
paulhunn
Hi
I have been set the following problem. Z2CO3(aq)+2HCl(aq) -> 2ZCl(aq) + CO2(g) + H2o(l)
We did the experiment in class to find the amount of HCl it would take to titrate the soloution. First by measuring an amount of Z2CO3 and dissolving it into 250cm^3 of water and using methl orange indicator to know when the reaction had taken place. We did this three times using 25cm^3 samples and i got a mean titre of 26.8cm^3
We are told that it is a group one element and the concentration of the HCl is 0.1
So using the formula M=number of moles/volume in dm^3 i rearranged and got 0.1*0.0268=2.68*10^-3 meaning that it would be 2.68*10^-2 for the entire soloution.
Knowing it will take 2 moles of HCl to react one mole of substance Z it would mean there was 1.134*10^-2 moles of substance Z in the 250ml soloution and knowing the original mass that was dissolved (1.5g) i can use the formula weight(g)/number of moles=molar weight which gave me 132.275g. Then knowing that the rest of substance Z is CO3 i can subtract their weights (12+16+16+16) which gives 72.275 and then halfing to find the molar weight of Z (because in the formula we have Z2) we get 36.1375. which is relatively close to potassium.
Does my method follow correctly?
And is the 3g that i am off from potassium enough to say there was a significant error in working or is it ok?
Thanks in advance
Paul
Approach is correct, error is too large for my liking (but it was very likely potassium as you think).
