If energy is created with expansion and it has no limit....?
The discussion revolves around the concept of potential energy in the context of the universe's expansion and the implications of infinite energy. Participants explore definitions of potential energy, the relationship between dark energy and potential energy, and the conditions under which energy could be considered infinite.
  • Some participants question whether potential energy can be considered infinite, suggesting that it is defined as energy that can be created.
  • Others argue that there is no potential energy creation associated with dark energy, challenging the definition of potential energy as proposed.
  • One participant posits that if the universe expands indefinitely, then energies such as dark, vacuum, and gravitational energy could also be created without limit, implying a form of infinite energy.
  • Another participant emphasizes that if the universe is finite, then creating an infinite amount of dark energy would require an infinite amount of time.
  • There is a discussion about the terminology used, with participants suggesting that the term "potential energy" may not be appropriate and seeking alternative descriptions.
  • Some participants express frustration over the repeated questioning about the existence of infinite energy and its relevance to the discussion.
Participants do not reach a consensus on the definition of potential energy or the implications of infinite energy. Multiple competing views remain regarding the relationship between the universe's expansion and energy creation.
Limitations in definitions and the complexity of energy conservation in general relativity are noted, with references to the difficulty in defining total energy for the universe.
Noduagga
Then is potential energy infinite (potential energy=energy that can be created)
Astronomy news on Phys.org
Think about how much this cost in terms of work! Absurd! It is as the perpetual motion ... :biggrin:
There is no potential energy creation in the creation of "dark energy" so I don't see that your "potential energy=energy that can be created" is a true definition at least certainly not in this case.
So how would you call the energy that could be created? Would it be infinite?
Only if the universe is infinite. What are you really trying to get at?
Ok I think we aren't understanding each other. Correct me if I'm wrong. As universe expands and more space time appears more dark,vacuum and gravitational energy appear too right? So, if expansion has no limit (universe can expand forever) then these energies could be created with no limit right? Infinite energy could appear right? That infinite energy that can appear with expansion is what i called potential energy...so...?
If the universe is infinite they you don't need to wait ... the DE is ALREADY infinite. I still have no idea why you call it potential energy. Do you mean that there is the potential for infinite energy? If so, you are using a completely non-standard definition of the phrase "potential energy".
Well supposing that universe is finite and expanding.
And yes that was the thing i meant to say. If calling it potential energy is incorrect what term should i use?
If the universe is finite then an infinite amount of DE would take an infinite time to create.
Do you understand the normal meaning of "potential energy"? If not, you should get clear on it.
I called it potential energy because i didn't find another way to name it but i knew it was somehow incorrect that's why i asked the question..so how could we name it?
Just describe it, exactly as you would do for any phenomenon or complex set of events for which there is no single name.
ok, you're right but just one last thing. if infinite energy can be created, could we say that there's (potentially) infinite energy ?
In an infinite universe or in an infinite amount of time, there can be infinite most anything. What IS this fascination you have with infinite energy? What's the point? Do you have some personal theory that you are trying to find support for?
Note that the total energy for the universe (including potential energy) is difficult to define for a number of complicated reasons. The following article goes into detail about energy conservation in GR, which is essentially what you're talking about here. Here's the link: http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
The total energy of the universe is irrelevant, only the energy density in the observable universe matters.
So, would we be correct if we say that energy is (potentially) infinite?
WHY DO YOU KEEP DOING THIS ? What IS it that makes you keep trying to get people to tell you that there is infinite energy. What does it matter? Did you not believe Chronos' telling you that it it irrelevant and only the energy density matters?
I have asked you a couple of times now why you keep asking this. Why do you refuse to answer?
Thread closed on this pointless discussion.
